Question about Xerox Office Equipment & Supplies
I want to calibrate the touchscreen on a Xerox WC7655
Codigo 05.283 xerox 7655
El manual responde que la DADF onde escanias tus papeles tiene un sensor malo adonde se sale el papel.
Esto es para la WC7655?
005-283 RAP
BSD-ON: BSD 5.2 - Document Stacking
DADF Stack Height Sensor Logic Fail.
Jun 14, 2016 | Xerox WorkCentre Pro 765 Laser Printer
How do i calibrate my nextbook tablet
You can adjust the touchscreen calibration by going to Settings-->Touchscreen calibration on your Nextbook.
Jun 20, 2015 | Nextbook Tablets & eReaders
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
Apr 12, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Panasonic Toughbook CF-30 Touchscreen Calibration
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Sep 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Lexmark X5500 MFP Touchscreen Calibration not possible
sounds like a pressure line/switch is bad broken or loose? just a thought :)
Jun 17, 2008 | Office Equipment & Supplies
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
