Question about Kenmore Microwave Ovens
Kenmore microwave oven /pizza oven Model 721.66993: turntable no longer rotates.
MicrowaveSvc
  • 9047 Answers
SOURCE: OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: The turntable keeps rotating when the dooe is open - Panasonic T994SFR
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
najah
  • 180 Answers
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
  • 3230 Answers
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
Is there pizza stone available for this product?
You do not give the make and model, but pizza stones are a generic sort of product, so you can just get one the same size as the turntable. Be aware it will not crisp or brown the pizza.
Apr 29, 2016 | Microwave Ovens
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
How to change kenmore microwave oven pizza turntable motor
check under neath if not from the inside b carefull they hold a 10.000 volt charge via a capasotr and if u touch it can kill
Feb 28, 2015 | Kenmore Microwave Ovens
The turntable on my kenmore microwave model number 790.4784 has stopped turning. It is a combined unit with the oven so to replace it means replacing both the microwave and the oven. Is there an eas
Cynthia. Look at this diagram http://www.searspartsdirect.com/Kenmore-Wall-oven-Parts/Model-79047842400/0582/0125400/P0508004/00002.html
The odds are that microwave is going to be a little complicated to fix that problem. You have to pull the microwave out and take it completely apart if you want to change anything. This is a high level job that requires security torx bits. I wouldn't really recommend trying to fix this one yourself because it's a really hard job. If you're gonna take the time out to do this job you're gonna have to uninstall it out of the cabinet and disassemble the entire cabinet off the microwave. I would recommend ordering the door switches, main board and turntable motor and replace them all if you're going through that effort.
Jan 14, 2015 | Kenmore Microwave Ovens
I have a Kenmore microwave model 721.61820100 and the turntable wheels just broke. Which part do I need to replace it. The glass part is not broken, just the wheels on which it rotates on.
The part you need is the turntable support. Sears shows the part on their parts site, and here's another source that I use. The support just slides onto the motor shaft through the hole in the bottom of the oven.
Dec 12, 2010 | Kenmore 80809 Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Microwave Ovens Logo
206 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
