Question about Hitachi CS33EB16 16" Rear Handle Chain Saw
Gas mix oil ratio - Hitachi CS33EB16 16" Rear Handle Chain Saw
What is the ratio for oil and gas in a 420homelite snowblower
Oil to gas ratio is a function of the oil. Mix the oil/gas according to what the oil says.
I use 100:1 Opti in all my 'mix myself' 2cycles.
Opti 2 2 Cycle Oil 34oz EZ Measure Bottle 20112 eBay
Feb 03, 2018 | Garden
Petrol & Oil mix - one third of oil to 1 gallon = what in litres
You need to go by the oil to gas ratio. 1/3rd what?
Google 50:1 (or whatever) mix in litres
and you will find this
Google 50 1 mix in litres Google Search
Mixing ratios. For a mixing ratio of 1 : 50 you need 5 litres of high-octane gas and 0.10 litres (100 ml) of STIHL two-stroke oil.
Dec 03, 2017 | Garden
Gas to oil mixture
Gas to oil ratio is a function of the oil you are using. Mix according to what the oil says not what the manufacturer of the engine says. Those ratios could/may be the same. IF you mix 16:1 oil (do they even sell that anymore ?) at a 50:1 ratio it will destroy the engine. There will be no problems at 16:1 as the oil recommends.
I have used 100:1 Optimoil (?) when I can find it instead of the recommended 48:1 of my 2cycle. No problems.
Mix the oil in ratio the oil manufacturer says to mix.
Sep 07, 2017 | Garden
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How do I mix gas + oil for the husqvarna 128 ldx(what's the ratio)
It should be 50 to 1 it would be good to get a ratio rite cup an use it to measure your oil for gas . How ever the saw mix oil should tell you how much gas it makes
Sep 18, 2014 | Husqvarna Garden
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
Jan 10, 2010 | Garden
Need to know oil to gas mix ratio for Craftsman 32cc, 360 cfm, 170 mph blower vac? Can someone provide ratio?
40:1 is the standard mix. Go buy one of the little containers ( 3.2 ounces) of 2-cycle oil and mix it with a gallon of gas in an approved container (like a gas can). How you mix it is, pour some gas in the container...about 1/4 of the gallon, then pour in the oil, mix well, by shaking the can then add the remaining gasoline and PRESTO, you have a 40:1 mix!
Nov 08, 2009 | Garden
How to mix gas and oil ratio
hello. the mix has not changed over the years. it is important however to use ryobi oil. go to any home depot and get the small bottle of ryobi oil that is enough for just one gallon of gas, use new gas fresh from the pump, and enjoy.
Aug 18, 2009 | Ryobi Factory-Reconditioned ZRDS11008...
Hitachi CS33EB16 16" Rear Handle Chain Saw Logo
Top Hitachi Garden Experts
Phil Walker
Phil Walker
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
