Question about Hoover Whole House Bagless Upright Vacuum, UH71214
Change belt on hoover whole house - Hoover Whole House Bagless Upright Vacuum, UH71214
How to replace belt on hoover UH71214
Hi, it's Cindy from Crucial Vacuum.
I have included a direct link to our youtube video on how to change your Hoover UH71214 belt: http://youtu.be/3qUAD2ewe8k
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-t-seres-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 25, 2014 | Hoover Whole House Bagless Upright Vacuum,...
Hoover replacementb belt 562289001
Try a vacuum cleaner repair shop, an appliance parts distributor, or Hoover directly.
Apr 07, 2014 | Hoover Whole House Bagless Upright,...
Hoover Whole House Bagless Upright. Belt Changed but Brushes arent moving
Take off the bootom plate and remove the brush assembly. Inspect both ends for any hair, string or anything else that might prevent it from revolving. Check to see that the ends are lubricated with some grease, just a bit. It should take care of the problem. The ends should turn easily and smoothly.
Oct 15, 2013 | Hoover Whole House Bagless Upright,...
Hoover Widepath Tempo - belt slips off when we start it. Can you help?
Perhaps the belt is stretched. Replace it with Hoover belt # 38528-033. Remove the rug plate on the bottom ( 4 screws ), and remove the brushroll. Place the belt around the motor shaft first, then position it around the brush, and push the brush back into the housing. Expect resistance from the belt, as it must be stretched several inches. After the brush is in place, turn it with your fingers to be sure the belt is centered, and not pinched between the brush and the housing. After replacing the bottom plate the vacuum should be ready to use.
Feb 18, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Help...can't replace the belt on a hoover upright ''futura''
You didn't say what the model number is, so, I will give you a link to a website that has instructions with pictures on how to change the belt. Once on this site, you will see two links for belt replacement. Click the one that is closest to your model.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Oct 02, 2009 | Vacuums
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover Whole House Bagless Upright Vacuum, UH71214 Logo
119 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
