Question about NCR 7197-1001-9001 - Realpos 7197 Receipt Printer
Printer does not regonzie the computer and wont print
Wont print, says ink is low.. ...but will print
problem could be not compatible with the windows program
most windows vista will not except any printer made before windows vista.
Apr 08, 2010 | Dell 966 All-In-One InkJet Printer
Wont prit
reboot the computer and the printer..
then try to do a "Print Test Page"..if it still does not print, turn off the computer again, unplug the printer from the back of the computer ( I assume it's connected via USB), then plug the printer on a different usb slot on the computer.. you may have to re-install the drivers. make sure you have the cd for the printer.
Hope this helps.
May 09, 2009 | HP DeskJet 840c InkJet Printer
Fix this promblem
1) Make sure the hold switch is not engaged
2) Make sure all software is installed - available from Sandisk's website if you have lost the CD
3) Reset the player by holding in the power button for 15 seconds
4) If the reset fails, update the Firmware from Sandisk's website
-Tha Mp3 Doctor
Feb 11, 2009 | SanDisk Sansa Clip MP3 Player
Wont print out from computer monitor
Your Print Screen key is only saving your screen into your clipboard.
Paste it into any Graphic (PAINT) word processing (MSWord) Presentation (PPT) programs then you print from there
Jan 16, 2009 | Office Equipment & Supplies
Printer wont print
open up the printer folder in your computer and then cancel the pending documents after that open SERVICES.MSC that u can easily find searching in your computer and after that look for print spooler restert that service 3-4 times and then restart your computer after that try and print if this oes not help leave a message i have a solution for that as well
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Canon bjc-3000 is not printing
Has the software for the printer been installed in your computer? Sorry if this sounds like a silly question, but I did the same thing, and it turned out I hadn't installed the software yet so it didn't recognize the printer.
Nov 16, 2008 | Canon BJC 3000 InkJet Printer
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
My computer wont print off my cannon pixma mp460
uninstall it.  Unplug the printer.  Then reinstall it.  Then plug the printer in.
Oct 11, 2007 | Brother HL-2040 Laser Printer
NCR 7197-1001-9001 - Realpos 7197 Receipt Printer Logo
24 people viewed this question
Top NCR Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a NCR Office Equipment and Supply Expert? Answer questions, earn points and help others
