Craftmaster lawnmower engine oil 944 367800 - Computers & Internet
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
Where is the oil plug underneath the mower?
Depending on what engine is on your Toro lawnmower, there may not be a oil plug under the mower deck. A briggs and stratton engine will have one, but if the unit has self propel then you will have to move the guard over the self propel cable. This is a 1/2 in bolt, you will also have to loosen the other bolt to swing the guard around.
On a Kawasaki or Honda, and even if you have a Tecumseh engine then just start the mower up for a few minutes and let the engine oil get warm, then shut the engine off and then lay the mower on the side that has the oil filler cap and put your drain pan under the oil filler cap. You can then drain the oil out of the oil filler tube. You can also do this with the briggs and stratton engine. I find this to be a very convenient way to change the oil.
Then put fresh oil back in the unit. I always suggest to put the engine manufacturer's oil back in the unit, or if that is not available then use another oil from another engine manufacturer. IF you use automotive oil, the oil will break down faster since the heat level for the engine on car is less than that of the engine on your lawnmower. The engine has a water cooled design, that keeps the engine temperature from raising over about 250 degrees F. The engine temp on your lawnmower can get as hot as 400 degrees F in the summer heat and being run for 30 minutes or longer.
A longer answer than you had hoped but I hope the information keeps your lawnmower running well for many summers to come. :)
Apr 04, 2011 | Toro Power Lawn Mower
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
I have a Mountfield HP474 lawnmower. We cannot locate the sump plug to drain the oil. Please could you advise. Many Thanks Gavin
According to the operators manual there is no sump plug, instead you "dump" the oil out using the oil fill.
Below is step by step instructions copied from the Operators manual:
Drain oil while the engine is warm being careful not to touch the hot engine nor drained oil
a) Place engine level
b) Clean around oil fill
c) Remove filler cap
d) Have a container ready to collect the oil
e) Tip the lawnmower on its left side so that the oil will drain from the oil fill
f) Place the lawnmower level and top up with new oil
g) Check the oil level on the dipstick
Oil should be at "MAX" mark
h) Close the filler cap and wipe off any spilled oil
NOTE: The oil capacity is about 0.6 liter
Sep 20, 2009 | Garden
If the oil in my lawnmower is overfull, how do I fix this?
should be a drian plug on the bottom of the mower engine, just drain and tighten up the plug and refill. they usually hold about 16 to 20 ounces of oil. Go buy briggs and stration oil at walmart or kmart just the right amount
Jun 13, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Oil leak tecumseh engine OVRM120-22053F
oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
clean cranksaft with fine sand paper
a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
heres the manual.pdf page 75
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
