Question about Toshiba Satellite A20-S207 Notebook
Vertical view desktop
Im havin difficulty in changin my desktop view to horizontal from vertical view by mistake the view on the latptop has been change, can u pls help me get back the horizontal view
  • 944 Answers
If you are using windows XP, (vista should be similar) then click "start", "control panel", "display" then select the "settings" tab. select "advanced". Depending which graphics driver you are using you should see a link or a tab labelled "rotation" or "rotate display". You can set hotkeys to perform the rotation if you want to simplify the process for the future. Hope this helps - please ask again if you need more info :)
Posted on Aug 31, 2007
When turned on there is a dark background with vertical and horizontal stripes
Sounds like you might have corrupted your programming. See if you can do an update online by going to the EasyShare website and searching for updates for your model. You maybe able to download and reinstall the software.
Dec 19, 2014 | Kodak EasyShare Z612 Digital Camera
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
    170
  • Vertical Viewing Angle
    160
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
Im in need of an Instruction manual for a Casio - CTK 411
HI. Click here to access the manual you seek. It will be necessary to print this PDF file out to view it horizontally, due to the fact that, the PDF file will read on a vertical format.
Aug 30, 2010 | Audio Players & Recorders
Where is the system battery on the hp pavillion 533c
Without the mother model/type it's impossible to tell you where the Bios Battery is located. But there's not much difficulty, generally only two types of alignments, as shown below, horizontally on the motherboard and vertically : a74f1de.jpg
Vertical,
Horizontal.
May 14, 2010 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
How do you change the spark plugs on a 95 isuzu rodeo with a v 6
not easy even if u can findum-if ur havin ignition problems try changin the plug wires n dist cap cause plugs r made tuff these daze or just take one out for inspection--also ign modules wear out also
Jan 14, 2010 | 1995 Isuzu Rodeo
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
How do i identify the wires of the lg 710s?
Vertical signal wire is yellow colour wire
Horizontal signal wire is White colour wire
Nov 22, 2008 | LG Studioworks 700S 17" CRT Monitor
I dropped my lap top and now my view is horizontal instead of vertical. how do I fix the view?
Wow thats strange? check to see if there is a Function key ( Fn on Fun ) and look at the F keys at the top of the key board. One may have come on when dropped. Hold down Fn key then push the F key. Hope this helps.
Nov 17, 2008 | Computers & Internet
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Toshiba Satellite A20-S207 Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
