Unable to initialize af 48 - Office Equipment & Supplies
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
How to remove error initial 48 in mfc j220 printer brother?
it shows that unable to print50. or remove paper jam at the back. but nothing is in..how can i resolve this problem
Oct 23, 2012 | Brother MFC-3360C All-In-One InkJet...
Dcp j125 unable to init 48
Unable to Init 48 printer Brother DCP-125 ???
Jul 28, 2012 | Brother DCP-J125 Inkjet Multifunction...
Print unable 48
unable to print 48 in brother dcp-j125
Jul 22, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc machine error AF
You have to fix the scanner flatcable on the pcb. Its disconnected :-)
Sep 25, 2007 | Brother MFC-210C All-In-One Printer
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
k24674
