Question about Hotpoint Kitchen Ranges
What rating fuse does a Hotpoint CIO642DDB induction hob require? I have the older fuse box with a fuse rating of up to 30amps. would this be ok?
2 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: induction hob childlock has come
www.caple.co.uk/documents/guides/C851i.pdf
but i need u to rate me
Posted on Aug 18, 2008
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
What does f31 fault mean on my hob
It means the fuse has blown on the filter board because one of the main power boards has failed. Not a cheap fix and requires a tech.
Jun 02, 2014 | Miele KM 6115 Black 75 cm Electric...
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
Dec 20, 2010 | Hotpoint Ovens
Couldnt find a replacement instruction manual for the de dietrich dt 1714v induction hob
Several posts regarding instruction manuals for De dietrich induction hobs. Goto "http://www.dedietrich.co.uk/hobs-induction-hobs-c-55_23_38.html" scroll to find your model - select it, then look for a link to download manual.
Mar 30, 2010 | Kitchen Ranges
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
My De Deitrich induction hob wont heat up.
It is OK. The voltage was the problem. As soon as we went on to proper power again the hob worked normally.
Jan 10, 2010 | Kitchen Ranges
Hotpoint BE72 Ceramic Hob - Overhjeats and goes into error. Have to switch off and allow to cool before being able to use again.
hob under guarantee thank goodness - new control panel fitted, solved the problem for a year then it all started again. Now won't switch on at ALL. Engineer just came says part obsolete so we qualify for replacement - am considering induction even if I have to pay extra as the hob itself doesn't heat up just the pan. Sorry I can't be more positive :-(
Jul 07, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
