Western digital 250gb not recognized
Ok, the computer got the this is the FBI virus that shut the computer down, after messing with it a while replaced the hard drive with a WD250gig hard drive and got Windows XP installed. I am able to get it to boot up but with out any sound though it shows the sound icon and that works but when you first turn it on it recognizes that there is a hard drive and asks you to press F1 to continue, then it will boot the hard drive, how do I get it to just recognize the hard drive without having to go through this process?
  • Computers & ... Master
  • 928 Answers
Sounds like a MBR is corrupt.
Click on the link provided. It will explain on how to fix MBR (Master Boot Record) Hope it helps. Fix the MBR Guide for Windows XP Vista 7 8 8 1 10
Posted on May 15, 2017
habib_101
  • 55 Answers
SOURCE: hard drive recognized as slave drive
You probably need the change the jumper on the hard drive itself. The jumper looks like a thin little cap that covers a set of pins on the back of the hard drive. You should see it next to when you power supply connects and most drives will usually have a diagram on how to change the jumper from a slave to a master.
Posted on Sep 11, 2006
SOURCE: External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
Posted on Jun 08, 2008
PABLOCSA
  • 1124 Answers
SOURCE: HDD both IDE or SATA 1 are not recognized
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Posted on Oct 06, 2008
RSBennett
  • 54 Answers
SOURCE: Hard Drive Not Recognized
It is rare that an IDE drive will not be detected during Windows XP setup. Try the following steps:
1) Verify that all connections are solid. The IDE cable is secured at the drive as well as the motherboard. The power supply is connected to the drive.
2) Enter the BIOS setup and verify if the drive is recognized there. If not, there is a connection problem.
3) If you are using any type of RAID, even if the drive is simply connected to a RAID controller, you will have to load those RAID drivers via floppy during the install process in order for your drive to be detected by the Windows installer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Posted on Mar 11, 2009
  • 125 Answers
SOURCE: sata hard drive not recognized by windows
If it is a new drive, then you need to partition and format it for windows to see it. To do this, click START, RUN and type in compmgmt.msc. CLick on Disk Managment. Look for the new drive, right click on it and select partition. When that is finish, right click the drive again and select format. Format the drive as NTSF..
Posted on Apr 04, 2009
Hi i have a western digital passport 320 gb P/N WDBAAA3200ABK-00 S/N: WX00A9928509 RECENTLY MY COMPUTER IS NOT RECOGNISING IT PLEASE HELP
Try a different computer if it doesn't recognize it either than its fried a tech could still try to take it apart and pull out the internal hard drive to salvage some of the data. good luck
Mar 03, 2011 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
My computer is not recognizing my Western Digital passport elite what do I do?
Have to check it in the Device Manager that the new device have been detected or not. It may happen that when the external HDD connects to the computer for the first time computer cannot detect it as it is not properly formatted in proper file-system. Open Computer Management and click on Disk Management and format the device correctly to operate.
Jun 21, 2010 | Western Digital WD Passport 250GB Portable...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
My computer recognizes the western digital but i cant view my files.
just update the chipset drivers of ur system form the vendors site,,, tat ll solve the issue...
Jun 02, 2009 | Western Digital 250GB MyBook External USB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
