Question about Sony PlayStation Portable (PSP) Console
Psp the game could not be started (80020321)
  • 7 more comments
  • jecca Aug 31, 2007
    thnx
  • kawthar Feb 08, 2008
    trying to run a PSP game through the memory stick, but I had an error message 80020321 "the game could not be started". How to fix this problem.
    Thanks,
    Kawthar
  • Anonymous Nov 25, 2008
    game opens but will not load (The game could not be started (80020321)
  • Anonymous Jan 26, 2009
    i have the same prob
    I cant find all of the movies that I downloaded?
  • samsteve Mar 07, 2009
    the game can not be started,(80020321)
  • Anonymous Apr 30, 2009
    i have games downloaded when i try to play them it says the game could not be started (80020321)
  • porterb_321 May 02, 2009
    I Resently Downloaded The Dj BLACK SQUARE game and doing all of the other tricks i know of to run other games still doesnot fix the cannot read game message. I have tried changing the ISO mode and even turning off several of the plugins i have to run psx games. None of these seem to be the right solution.
Press select and change the UMD **** from normal to sony NP9660
Posted on Jan 26, 2009
Trying 2 run a psp game through the memory stick, but I had an error message 80020321 "the game could not be started". How to fix this problem.
Look up for the configuration.
Posted on Sep 03, 2007
Thanks Sendoh111neo for that.Works great now
Posted on Mar 18, 2009
Game will not pop up
Posted on Jan 11, 2008
I;m having the same problem with my psp...pls help me fix my psp
Posted on Nov 25, 2008
  • aacruz68 Apr 15, 2011
    i tried of all if the solutions..like changing the iso mode, and check through the configuration, and upgrading it..but still it don't work..what will i do?
5 Suggested Answers
SOURCE:
bravsman
  • 94 Answers
SOURCE: all of my ISO games suddenly couldn't be started. error 80020321
just press select botton to display the vsh menu and select umd iso mode and change the normal to sony np9660 that's all
Posted on Nov 22, 2008
leethedeuce
  • 4472 Answers
SOURCE: update version error (80020321)
What version did you update to? most likely the lens is just dirty a little alcohol and qtip and the lens can be cleaned but be sure to be careful. You can also buy a cleaning disc as well. If you need further assistance let me know, also please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: my psp won't play my games it displays an error of
**** your dad's *****§!
if you hold the right trigger then power on your console you should get the recovery menu then select configuration then umd mode and try
eitherm33 no umd driver or sony np9660 -no umd driver if you are using custom firmware
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: 80020321
its maybe cause you have no UMD and you"re trying to run an ISO file. to fix this, you can press select button and choose in the UMD mount mode: SONY NP6990. if this isnt working just put an iso in your UMD drive.
Posted on Sep 27, 2009
How to fix my psp 2004 problem the game could not be started (80020321) pls help,
This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load.
Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error.
Hope this helps you!
Mar 03, 2011 | Sony PlayStation Portable (PSP) Slim...
My psp2000 slim has an error 80020321. When start the game it deos not starts it shows (The game could not be started)(80020321).I tried to fix but i could not.It could show the setting of memory stick by...
there could be 2 problems
  1. your game might not be downloaded properly ..or completely
  2. Go to the recovery console on yr psp2000 (turn off psp press on R button & turn on your psp while pressing on the button) & change the driver to D33 driver.
Sep 02, 2010 | Sony PlayStation Portable (PSP) Slim...
Error coming 80020321 on all games
press select, then choose umd iso mode and press right, it will eventually change to m33 driver and then exit .....
Nov 13, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp games intalling problem
5.00 m33-4 is a very old custom firmware and all the new games wont work. you need to upgrade to gen-d2 or higher.
Nov 03, 2009 | Sony PlayStation Portable (PSP) Slim...
Sep 27, 2009 | Sony PlayStation Portable (PSP) Console
ok u have to download an psp emulator and custom firmware
Aug 24, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
1,559 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
