Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 3500 code sc542 - Ricoh Aficio 2022 All-In-One Laser Printer
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
ginko
  • 19396 Answers
SOURCE: ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Posted on Nov 19, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio 3410 reset codigo sc542
replace tirmistor and clear code by using clear mode 107........
Sep 02, 2012 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh aficio 2232c sc542 error
Try this reset:
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
  • Enter 107
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
747 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
