Question about Frigidaire PLMV169DC Microwave Oven
Electrolux microwave plmv169000 dead - Frigidaire PLMV169DC Microwave Oven
I need microwave Electrolux model is 318279620A
It is not clear what your question is, but you can find out just about anything about Electrolux Microwaves at this site:
Microwaves Built in and Over the Range Microwave Electrolux
Heinz
Sep 11, 2016 | Electrolux Microwave Ovens
Are the doors from electrolux eml38405x microwave oven can fit to electrolux emc38905x?
Replacing the door is one of the most demanding service interventions in the microwave. Substitution is possible only with the original door, otherwise may cause leakage of radiation what is very dangerous.
For identity doors of two different models of the microwave please contact an authorized service center.
Dado
Apr 11, 2015 | Electrolux Microwave Ovens
WHERE IS THE FUSE LOCATED ON A ELECTROLUX E30M065GSS MICROWAVE
According to the wiring diagram for this microwave: http://www.manualsdir.com/manuals/79797/electrolux-e30mo65gssa-e30mo65g-e30m065gss.html?page=8
The fuse is located where the 120v line cord connects to the unit internally. Make sure the unit is unplugged prior to servicing.
Feb 02, 2015 | Electrolux Microwave Ovens
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
I WOULD LIKE TO DOWNLOAD MANUAL FOR ELECTROLUX MICROWAVE/CONVECTION/GRILL OVEN MODEL EM20EC80SL PLEASE
I found it! There isn't a direct link from the Electrolux home page (shame on their webmaster!), but I got it with a search engine.
The first 12 pages are important generic information about microwave cooking; after that it gets into details on your model.
Mar 08, 2011 | Electrolux E30MO65GSS Convection Microwave...
Microwave button not working. But other buttons are working, like grill and combination. Is there any service center in Kolkata?
c.c. : Mr. M. K. Das, Head-Mktg. (Kolkata)
ELECTROLUX KELVINATOR LTD
15, Remount Road, Kolkata-700 027 – Fax : 2448-2065
Khosla Electronics Pvt Ltd
Location - Ballygunge, Kolkata-700019
Also See - Microwave Oven Dealers Electrolux,
Location - KOLKATA-700097 (Also serves Kolkata)
Jul 10, 2009 | Electrolux Microwave Ovens
Mw will not heat
usually if MAG is RF dead the unit will function but not heat...
Mar 06, 2009 | Electrolux Over-the-Range Microwave
Frigidaire PLMV169DC Microwave Oven Logo
16 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
