Question about Exercise & Fitness
York heritage t101 treadmill speed sensor malfunction L5 i have removed sensor cleaned replace treadmill cuts out as soon as it picks up speed please help x
  • 3 Answers
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Posted on Feb 03, 2010
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: the treadmill starts then after a few seconds it
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
Posted on Mar 09, 2010
  • 773 Answers
SOURCE: I have a York z16
LS or L5 error is the speed sensor. Because it is such a vague code I can't just tell you exactly what's wrong with it. I can tell you what it may be.
If you are lucky it's just a fuse. If you have belt movement, it's likely that its just a fuse. If there is no belt movement, it can be a computer failure. the MCB will need replacing.
If you have belt movement and you check the fuse, and its not blown, then the speed sensor is no good and needs replacement.
In most cases its a fuse.
Good luck, hope this helps!
Posted on Oct 25, 2010
tunde007
  • 2382 Answers
SOURCE: i have a york heritage
Hi, L5 or LS is short for Low Speed error. It basically means that the speed sensor is not picking up a signal. Unfortunately its a pretty vague error code and can be caused by several different problems. First you have to determine whether or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS without belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good, you will need the MCB replaced. If you have sufficient output its drive motor related. Aside from a problem with the drive motor, it is possible that another factor is stopping the motor from turning (ie locked up roller bearing, foreign debris, etc.) If it is a case of
faulty electronics the next question is, is to figure out what caused it to fail. Most MCBs don't fail on their own, something else usually causes them to fail. The bottom line: The LS error can be
complicated and should really be inspected by a professional to full assess the issue. What I am saying is call the manufacturer and if it is under warranty send the treadmill back.
Posted on Apr 24, 2011
Hi we need help knowing how to fold down our York t101 Treadmill please
Try Googling (York)(t101)(manual) without parens for instructions.
May 14, 2018 | York Exercise & Fitness
Speed sensor L5
follow this steps and fix it. God bless you
SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement
This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board.
NOTE: USE THIS FOR DIAGNOSING THE PWM/RELAY COMBO BOARD
Oct 21, 2013 | Landice Exercise & Fitness
I have York intensity treadmill and its not working, the L 5 keeps showing on screen.
Test the input voltage 2)test the relais 3)see sensor speed wiring 4) test terminal motor.
God bless you
Oct 09, 2013 | York Exercise & Fitness
Fixing speed setting L5 York Heritage T102
i noticed that the speed sensor is rarely faulty,, a fuze wouldnt let you do anything...
i usualy take the brushes out of the motor and clean the speed sensor and surroundings of dust and bits of steel dust, makes them go fine,, i fix treadmills for a job and everybody always told me its a elec board problem but this always works for me.. clean and rebend the brushes blow the speed sensor with aircompressor. sometimes i have to reposition the speed sensor and i glue it into place when i found the swt spot.
Apr 19, 2012 | York Barbell Home Use Fold-Up Treadmill
THEREIS A FAULT CODE L5 COMING UP ON MYT102HERRITAGE TREADMILL CAN YOU HELP
Jun 06, 2010 | York Exercise & Fitness
I have a error reading of l5 or ls not too sure york fitness z16
Dec 29, 2009 | York Exercise & Fitness
York t101 treadmill ls error
May 11, 2009 | York Exercise & Fitness
Ls error
Showing l5 or ls on sceen of my york t101 treadmill please help me out thanks.
May 09, 2009 | Exercise & Fitness
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Exercise & Fitness Logo
422 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
