Question about Kenmore 15129 Built-in Dishwasher
Water leakage through vent into sink when dishwasher is in use.
  • 833 Answers
This is the diversion solenoid. Water from the pump is sent to either the drain or back up to the nozzles. It has something in it which is holding it partly open. It may be possible to clean it.
Posted on Dec 26, 2007
What is wrong with my lg dishwasher it is flashing E1
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage.
Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
see http://www.appliancepartsquick.com/LGDishwasherFaultCodes.html and
http://www.fixya.com/support/t193162-error_code_e1_lg_dishwasher
Jun 23, 2014 | LG 24 in. LDF 7811 Stainless Steel...
E1 message on smeg DWI 614
see this causes and fix it. God bless you
E1--Leakage error--Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection (sink drain hose) is not over 20". Impeller of the washing pump is worn away
Sep 28, 2012 | Dishwashers
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 comes up on screen and alarm goes off, how do I fix it?
Leakage error > Condition: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Solution:
Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
Mar 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Getting error message E1 what does this mean
E1 leakage error
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Sep 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
Aug 30, 2009 | LG Dishwashers
Water does not get pumped out of dishwasher
I have had this problem a few times. For me all I had to do was unscrew the vent/overshow knob on the sink and clean out the vent. Because the vent is clogged, it does not allow the water to flow out. Clean out the debri and screw the vent cap back on- should work fine.
Aug 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code e1 lg dishwasher
Can be one of the following:
Sump assembly.
(sink-Drain Hose) is not over 20.
worn away.
Oct 04, 2008 | Dishwashers
There is no water coming in the dishwasher
The water pipe to your dishwasher is most likely split and/ or kinked.
Dec 18, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Kenmore 15129 Built-in Dishwasher Logo
56 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
