Question about Craftsman 22" Gas Hedge Trimmer
Diagram for replacing fuel lines on a Sears, gas bush wacker hedge trimmer
3 Suggested Answers
sparksflyin
  • 47 Answers
SOURCE: fuel line replacement
pull the lines off do only one at a time one should stick in the tank 1/4 inch which is your return the second one is your pick up which has a filter in the tank attached to it take a piece of stiff wire or a clothes hanger and bend a tight hook on the end just big enough for the fuel line to fit in it fish the wire in the tank and try to hook the fuel line then pull it out of the tank to take the filter off it might take a few tries but you will get it after that pull the line out from the top not the filter side take the new line and feed it through if you cut a 45 degree angle at the end of the line it makes it easier to feed once you get it in all the way use your piece of wire to hook it through the filler and pull it out then attach your fuel filter then shove it back in the tank like i said it may take you a few times but you will get hope this helps
Posted on Feb 08, 2009
  • 63 Answers
SOURCE: How much oil do I mix with gasoline for my 22 25cc
50:1 petrol/oil
Posted on Jul 25, 2010
Why won't it start?
I hate those little bulb primers. They get cracks & pin holes that completely ruin the operation of blowers , mowers, & weed wacker half of which you can never see. But that's just the beginning. The fuel lines do the same thing. And the fuel lines are made out of a material that cracks due to contact with fuel in 5-8 years. So here's my rule of thumb: 1) replace all the fuel lines & bulb if there's every any problem what so ever with priming the tool. 2) rebuild the carb is fuel drips out. Since I follow this rule now I make trips to the store a lot less & I've had a 100% success rate at fixing small motors. A little hint, some Ace Hardware stores sell the fuel line that does not crack by the foot. It's about $1.89/ft. Good luck.
Aug 05, 2015 | Sears Garden
Tanaka tht210b hedge trimmer is losing power. Why?
Weed wacker had same issue. Fuel lines are swollen closed do to ethonol.
Jun 21, 2014 | Tanaka Garden
I need my Electric Bush Wacker Hedge Trimmer/Need the cord replaced.Where can I get it repaired?
any sears repair center would be glad to do this for you , also if your handy with a simple screwdriver , then they also will sell you the parts to fix it your self , id suggest replacing the entire trigger and cord assembly just for piece of mind, also a ck of the motors brushes (life) would be a smart thing to do as well
May 23, 2014 | Craftsman Garden
Weed wacker dies when you give it the gas.
2 cycle or 4 cycle?
2 cycle have two fuel lines running between carb and fuel tank.
Check for crack or break in either line.
You can buy a kit to replace both the pick up line and the return line.
Make sure to note which line is the pick up(filter in tank attached to line) the other is the return.Good Luck
Feb 18, 2012 | Craftsman Garden
Need to fine gas tank replacement part for craftsman weed wacker model number 04182N501231
Hi mperez40
Go to the following webpage and you will be able to locate what you need and be able to order it also.
It is the Sears Parts webpage with will also have phone and email support in case you canhnot locate the part by yourself.
Please rate me
http://www.searspartsdirect.com/partsdirect/product-types/Grass-trimmer-weed-wacker-Parts
Jun 25, 2011 | Craftsman 25cc Gas Line Trimmer
I have a craftsman gas weekwacker model 356.791520 is there any diagram of the fuel lines. I think I repaired them wrong.
Looks like you've possibly referenced the wrong model # for your trimmer. There is a diagram available for model 358.791520, but not a 356.791520. You can find it here - http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791520/0247/1503820?searchedModel=791520&blt=11.
Once you get the Sears numbers for parts you need, you can find replacements for them at HyperParts.com's cross-referencing page here.
May 19, 2010 | Craftsman 25cc Gas Line Trimmer
Gas trimmer - not getting gas
the primer bulb needs to be replaced, if it has a small hole in it
Sep 09, 2009 | Garden
Craftsman 22" Gas Hedge Trimmer Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
