Question about Vacuums
Replacement hose for rowenta Air Force 24v - Vacuums
I broke the Air flow adjusting knob and can not get air to release on my Musting 255 can you help.
replace them you can get them from guarantee vacuum and sewing center
Mar 17, 2014 | Vacuums
Rowenta DE880 replacement cord. Where to order one?
1st, check with your local VACUUM dealers to see if they have one. If not, check online by typing into your search browser (eg- google) "Rowenta DE880 replacement cord" and various stores will come up where to get on online, with a small shipping fee. Compare prices, as not all are the same.
Oct 14, 2013 | Vacuums
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Jul 11, 2011 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Need a filter for rowenta infinium vacuum cleaner
Although it sounds to me like you have a clog in your hose (remove hose and try slipping a heavy butter knife through it, end to end) here is a link to Rowenta manual..lists part numbers for replacement parts.
http://www.rowenta.com/NR/rdonlyres/9A747036-B60E-4F70-96BF-3370EDADAB54/0/Canistervacummcleaners_InfiniumGB.pdf
www.rowenta.com
Sep 13, 2009 | Rowenta RO7011 Bagless Canister Vacuum
Need replacement collar with 3 pegs connecting
Have been in touch with Rowenta spares agent and am
told no parts available for model RB02, so will have to
improvise
Sep 02, 2009 | Rowenta Vacuums
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
