Question about Ricoh Office Equipment & Supplies
Sc 202 gestetner mpc 1500 - Ricoh Office Equipment & Supplies
4 Suggested Answers
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
M2Tech1
  • 313 Answers
SOURCE: mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Posted on Jul 14, 2010
  • 435 Answers
SOURCE: ricoh mpc 2000 when machine starts without disply gives error codes. error message gives sc 202 in ark disply please give me detailed reply
Video might not help but this problem is due to the charge spring arching on the back of pcu, suggested fix eould be to restore spring to its original condition and add conductive grease to the charge plate on tge rear of the pcu. Hope it helps
Posted on May 03, 2013
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Ricoh mpc 2000 when machine starts without disply gives error codes. error message gives sc 202 in ark disply please give me detailed reply
Apr 18, 2013 | Office Equipment & Supplies
Mpc 1500s sc 202 and af 1075 sc 995
Jul 10, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Gestetner DSc424 says contact service provider when turner on
That depends on the service code that appears on the screen. The code will start with "SC" and then have a set of three numbers -- those numbers will tell you what the problem relates to. If it's an SC 515, for example, it's a problem with the first paper tray and can probably easily be remedied. Some other problems will require more work and possibly new parts.
Feb 02, 2009 | Gestetner Copier
"A"
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Product Gestetner 3245 It has sc 543-00 problem
Fusing overheat error.  It may require a thermistor or a new lamp.  Prices vary by dealer.  You would have to contact a dealer in your area to find out.
Aug 21, 2008 | Gestetner DSm645 Digital Imaging System
65 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
