Question about Magellan RoadMate GPS
Recover Magellan RoadMate deleted data - RoadMate Magellan GPS
SOURCE: Magellan Roadmate 700
If this does not work. What worked for me was unplug unit, hold the "-" "+" and repeat buttons down and while holding down press the power button. Hold down until unit powers on. once you release the buttons, the secret menu will pop up.
Posted on Nov 30, 2007
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
SOURCE: Magellan Roadmate 360 reset
I called Magellan and they told me that the previous destinations hold only 20 addresses and the new ones will override the old ones. I have more then 20 previous destinations and it just keeps adding new ones to the list.
Posted on Sep 20, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 5 Answers
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Posted on Dec 18, 2009
Hello, I want to download the latest map update for my Magellan Roadmate 3065, but unfortunately it's out of storage. Is there any way i can clear the memory?
Normally, it is done via a computer and loads and unzips it to the computer, then it over-writes the map data already on the device, so it doesn't need additional storage.
Did you load Content Manager and load from there?
http://support.magellangps.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=272
RoadMate 3065 - Software Update - Magellan Support - Magellan GPS
support.magellangps.com/support/index.php?_m=downloads&_a...272
Aug 28, 2012 - Description. MagellanĀ® RoadMateĀ® 3065 Software Update - Installation Instructions. To install this software update you will need to install Content Manager. Content Manager is a computer application that syncs with your Magellan GPS navigator to deliver new map updates and product information.
Apr 16, 2018 | Magellan GPS
I need to know how to delete addresses that I do not need anymore on my Magellan RoadMate 1440
Here is a video that explains hoe to add, edit, AND DELETE address book entries in a Magellan Roadmate. The delete process is in the last minute or so if you don't want to view the entire process.
How do add edit and delete address book entries Video Demonstration
Oct 27, 2016 | Magellan GPS
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Delete info
You can not erase a destination off the hard drive of your gps. When each one of the users gets full it will auto delite the oldest one.
Jan 08, 2008 | Magellan RoadMate 300 GPS Receiver
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Deleting previous destinations and unneccesary addresses
goto prefences/deleate active track, should also be able to clear it if it was placed in routes by checking folders and select it,next press menu, then select deleate
Nov 30, 2007 | Magellan RoadMate 700 GPS Receiver
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
- If needed please ask more questions prior to rating -
Nov 03, 2007 | Magellan RoadMate 700 GPS Receiver
this is not exactly what youare looking for but it will worth to know i guess. My 700 has auido problem. when i turn it on, i donto get any sound output. If you do the followign, configuration/diagnostic/audiotest, i recover the sound, till i touch sound volume bottom. It works fine considering nto everyday i need sound. I suggest you to
Aug 01, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
61 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
