Difficulties with inputing a password - Televison & Video
Having difficulty logging into my paypall account
Paypal has a link you click on if you have forgotten your password. You will have to prove the you are entitled to access that paypal account by answering some security questions.
Dec 22, 2013 | Computers & Internet
Electronicaly challenged
Could you please tell me what is hooked up to your receiver and via what inputs? Thanks.
Jan 16, 2008 | Denon AVR-2308CI
Tip
How To Change Password Of Users In Windows XP
On Internet, I found so many people are confused about how to change the passwords of users in Windows XP even though it is a easy job. As far as we know, changing logon password of our Windows regularly is a good habit to help keep our PC secure, I just researched and found out the below ways to change the password of users in Windows XP. You can use either one to achieve your goal.
Follow the simplest ways you thought to change your Windows XP logon password:
If you know any other interesting way, please let me know through comments.
Using Control Panel
Difficulty: Easy
Time Required: Changing your Windows XP logon password usually takes less than a few minutes
Here’s How:
go to Start –> Control Panel –> User Accounts
Tip: You can also open control panel by Start –> Run –> control. This will open Control Panel.
Select the user for which you want to change the password and select Change my password.
Note: you must need appropriate privileges to change the password of another user.
Using Ctrl+Alt+Delete
Difficulty: The easiest one in my opinion
Time Required: It just takes me one minute
Here’s How:
If your press Ctrl+Alt+Del when you are logged onto your Windows XP machine, it will show you the classic security options.
Select change password and change the password of the logged on user.
Note: If the security options does not appear. Task manager shows up instead of the security options. Just go to Start –> Control Panel –> User Accounts –> Change the way Users Log on or off.
Uncheck Use the Welcome Screen. Log off and logon again. Now pressing Ctrl+Alt+Del will show the security options window.
Using Command Prompt
Difficulty: medium
Time Required: It may takes a few minutes
Here’s How:
go to Run –> cmd.
Command prompt will open. Use the following commands to change the password:
net user username password /domain
Replace username with the original username and password with the new password you want to assign to that user. /domain is optional. If you are in a domain environment, specify the domain name otherwise, if you’re using a local user, leave /domain. If I want to change the password of user Sanix to 12345. I will issue the following command at command prompt:
net user Sanix 12345
It will change the password of the user Sanix to 12345.
Note: if you’re not logged on as an administrator, you will get the following error:
“System error 5 has occurred. Access is denied”
Using Control userpasswords2
Difficulty: Easy
Time Required: It may takes less than a few minutes
Here’s How:
go to Start –> Run –> control userpasswords2
This will open the classic user accounts management window. Select any user and select reset password.
Using Computer Management Console
Difficulty: Easy
Here’s How:
right click My Computer –> Manage –> Local Users And Groups –> Users
Right click the username for which you want to change the password and select Reset Password.
If you compare the ways hereinabove carefully .You’ll find that the premise of using above ways to change your PC users password is you must logon the system with a user who has the appropriate privileges to change the password of another user. But if you forget any user password including administrator, what can you do?
Tips:
Windows Password Recovery 6.0 is your best choice, it is an easy-to-use tool designed for resetting local administrator and user passwords on any Windows system. If you have forgotten your password , or are locked out, or you do not have access to the password of the system. No need to call a technician, no need to re-install anything, and you certainly don’t need to reformat, just download this effective utility .
Free Download Link : Windows Password Recovery 6.0
Quick Start: Get a quick start by following the step-to-step tutorial here…
on May 18, 2010 | Computers & Internet
I can' t acess my yahoomail through facebook
try contacting yahoo technical support
May 26, 2012 | Yahoo Mail
Blue screen that says RGB on my vizio
I'm sorry for the difficulties you're experiencing in watching programs on the TV. Since the screen says RGB, it appears that you've selected input as RGB(VGA, also known as PC input). If you have nothing connected to PC input (RGB), please change the input to HDMI or component or what ever it is by using the input button on the Remote of the TV.
In some TVs INPUT Button is labeled as TV/Video. Press it repeatedly to change the input from one to next.
Thanks for understanding. Please let me know if you require any clarifications.
Jul 05, 2011 | Vizio L32 32 in. LCD HDTV
Having difficulty in connecting to x box live have changed the router name and input a password from the bottom of the router
disable firewall in the router and open the following ports in the router:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
Jan 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Echo into mixer
I think the Echo's output goes into the mixer's input.You should be using one's output into other's input...that's how things work.If you r talking about both the system's input then they won't work with each other. Other thing is that if it's mono then there r cable available for the use which transfers mono to stereo input and vice-versa.
Jun 07, 2009 | Audio Players & Recorders
Wow got to hard mode but its starting to get a little tricky !
The only way to unlock "god" mode is by beating the game on "The One" difficulty. Sorry. =(
Mar 02, 2009 | Atari The Matrix: Path of Neo for...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
