Question about Baby Gear
WHERE WOULD I FIND AN INSTRUCTIONAL SHEET K6855543- CONVERSION FROM ENGINE TRANSFER PUMP TO IN TANK FUEL PUMP MODULE
  • 37 Answers
SOURCE: 85 Chevy pick up starts fine but stalls out on
speed control sensor estimaternotfree@yahoo.com
Posted on Feb 22, 2009
  • 239 Answers
SOURCE: access to the fuel pump assembly
i'm sorry to say the only way to get to the fuel pump is to drop the tank.
hope this helped.
please rate good.
Posted on Mar 02, 2009
motor1258
  • 6674 Answers
SOURCE: Car keeps stalling has all new parts
Run it into autozone or Pep Boys and get a free trouble code scan, and see what comes up, then we can go from there.
Posted on May 26, 2009
  • 51 Answers
SOURCE: 1988 f250 no power at fuel pump ,no fuel press.
Behind the air cleaner box, there are two relays. Over time they corrode and get stuck...change them out and see if that improves the situation.
Posted on Aug 20, 2009
mark24354
  • 776 Answers
SOURCE: 2003 CUMMINS STALLS BELOW 1/2 TANK RUNS FINE ABOVE
Just a suggestions but...
Check fuel filter.
Also add some fuel conditioner (e.g. HEAT for diesel) to get rid of any water that may be in your system.
Posted on Mar 19, 2010
How do I change the fuel pump in a 2009 GMC Acadia
drop the fuel tank and remove the circle lock. Youll see it when you take the cover off.
Feb 03, 2015 | GMC Cars & Trucks
My gas gauge dosent work how can I fix it
You will need to remove the gas tank and replace the fuel level sensor inside the fuel tank.
The level sensor is part of the electric fuel pump "module" Here is how to change that part.
  • 1. Start the van's engine. Open the fuel cap and remove the fuel pump relay from the engine's fuse box. Look for the engine to stall, signaling that the fuel pressure is gone.
  • 2Disconnect the van's negative battery cable.
  • 3. Unbolt the fuel tank's straps and lower the tank just enough to access the fuel pump flange. You can have a second person lower the tank, but it might be easier to use a floor jack with a wood block.
  • 4Remove the small locking pin on the pump's electrical connector with needle-nose pliers, and disconnect the electrical connector. Press the retainer tabs on the fuel lines and disconnect them from the pump.
  • 5Unscrew the pump's locking ring with a strap wrench or a similar hand-made tool that can grip the large ring and turn it.
  • 6Pull the water pump out of the tank, then remove and discard the O-ring from the fuel tank.
  • 7Pry back the locking tabs connecting the inlet filter to the pump reservoir using a thin screwdriver and remove the filter. This is only needed if this filter is in good condition and you must transfer it to the new pump.
Installation
  • 8Lubricate the O-ring for the filter with engine oil and connect it to the outlet of the filter. Push the filter onto the pump reservoir's inlet and make sure the locking tabs engage.
  • 9Install a new O-ring onto the seating hole on the fuel tank.
  • 10Insert the pump module into the tank, tilting it at an angle and making sure you don't damage the filter or the pump float. Make sure the module is properly seated.
  • 11Screw the retaining ring into position on the pump module.
  • 12Reconnect the fuel lines to the pump using their quick-connect fittings and the electrical connector with its locking pin.
  • 13Connect the tank back to the van using its straps and strap bolts.
  • 14Reconnect the fuel pump relay and negative battery cable
Jul 02, 2012 | 2000 Chrysler Grand Voyager
What side is the fuel pump for 2002 lincoln ls v6
2002 Lincoln LS uses a saddle-type fuel tank consisting of 2 fuel pump modules. A fuel transfer pump in the left side of the fuel tank supplies fuel to the right half, which contains The Fuel Pump Module (FPM). The FPM contains the fuel level sensor and an inlet filter. The FPM is controlled by the Fuel Pump Driver Module (FPDM) which is integrated into the Rear Electronic Module (REM) Fuel pressure is regulated by a pulse-width modulator in the FPDM which cycles the fuel pump on and off at varying intervals depending on engine load and RPM. The FPM supplies fuel under pressure to the fuel injection system supply manifold and a fuel level signal to the fuel gauge on the instrument panel.
It is recommended that if one of the fuel pumps fail that BOTH pumps be replaced as a set to avoid repeat repairs. (If one pump has been running for 1500 hours and the motor is worn out, the other pump also has been running for 1500 hours and is very likely to fail shortly thereafter.)
Nov 22, 2011 | 2002 Lincoln LS
I need to replace the fuel pump on my 2001 Saturn L200 with a 2.2 L Engine. What is the best procedure?
Fuel Pump REMOVAL & INSTALLATION 1.9L Engine To prevent excessive fuel spillage, whenever the tank is removed from the vehicle it should be no more than 1?2 full. Removal of the fuel pump module assembly requires the removal of the fuel tank.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Fuel feed and return lines from the filter/pressure regulator
    • Fuel pump vapor line from the fuel tank vent pipe
    • Fuel pump module retaining ring with service tool SA9156E. A 1?2 inch breaker bar will loosen the lockring
    NOTE: To prevent bending of the sending unit float arm, lift the pump module up slightly to disengage the orientation tabs in the tank. Rotate the module 90 degrees clockwise until the fuel lines are facing the 1 o'clock position.
    • Fuel pump module from the fuel tank until the bottom of the pump module is close to the fuel tank opening
    • Tilt the pump module approximately 45 degrees to the right hand side of the tank and lift the pump from the fuel tank
    • Fuel pump to tank seal and discard it
    To install:
  4. Install or connect the following:
    • Fuel pump module into the fuel tank by orientating the float to face the right side and tilting the module approximately 45 degrees
    • Fuel pump into the tank and rotate the assembly 90 degrees counterclockwise to align the module tabs with the slots in the tank
    NOTE: The fuel pump retaining ring cannot be properly installed if the flange locator tabs are not aligned with the slots in the fuel tank.
    • Retaining lockring with tool SA9156E
    • Vapor line to the fuel tank vent pipe
    • Fuel feed and return lines to the filter/pressure regulator
    • Fuel feed, return and EVAP canister purge line in the fuel tank retaining clip
    • Fuel tank
  5. Start the vehicle and check for leaks, repair if necessary.
2.2L and 3.0L Engines
    • Fuel tank
    • Fuel lines from the fuel pump module cover
    • Fuel pump module retaining ring with a Sending Unit Wrench, J43827
    • Pull the retaining clip toward the float arm and lift up
    • Fuel pump straight up from the fuel tank
    • Fuel pump tank seal and discard the seal
    • Fuel feed line from the bottom of the fuel pump cover with Clamp Pliers J43914
    • Fuel pump electrical connector Fig. 1: Remove the fuel pump cover lockring-2.2L and 3.0L engines 9306zg57.gif
    To install:
    • Fuel pump feed line to the cover
    • Fuel pump to the new seal
    • Fuel pump cover lockring with tool J-43827
    • Fuel lines and wiring harness
    • Fuel tank
Jan 29, 2011 | 2001 Saturn L-Series
How do i change a 2004 Lincoln LS fuel pump?
Hi. here's how to change the fuel pump. The actual electric fuel pump is in the tank on the right side. The tank is directly below the rear seat. If you remove the seat bottom you will find a 6 inch or so cover. Under the cover there is a plastic, threaded collar that locks the fuel pump into the tank. The driver's side also has a pump, but it works only my venturi effect from the electric pump on the other side. This pump is used to equalize the fuel level from left to right. The drive shaft tunnel prevents all but the very top of the tank from communicating left to right.
Aug 12, 2010 | 2004 Lincoln LS
Replace fuel pumpand moddual on a 2001 jeep wrangler sport 4.0l in side tank assembly
Fuel Pump Removal & Installation To Remove:
WARNING
The fuel system is under constant pressure, even when the engine is off. This pressure must be released before servicing the fuel pump module.
  1. Drain fuel tank and remove the tank.
  2. Thoroughly wash and clean area around pump module to prevent contaminants from entering tank.
  3. The plastic fuel pump module locknut is threaded onto fuel tank. Install special tool #6856 to fuel pump module locknut and remove locknut. The fuel pump module will spring up when locknut is removed.
  4. Remove the module from fuel tank.
To Install:
CAUTION
Whenever the fuel pump module is serviced, the module gasket must be replaced.
  1. Thoroughly clean locknut threads and mating fuel tank threads. Use a solution of soap and water. Do not use carburetor cleaner to clean threads.
  2. Using new gasket, position fuel pump module into opening in fuel tank.
  3. Apply clean water to locknut threads.
  4. Position locknut over top of fuel pump module.
  5. Rotate module until arrow is pointed toward front of vehicle (12 o'clock position). This step must be done to prevent float/float rod assembly from contacting sides of fuel tank.
  6. Install special tool #6856 to the locknut.
  7. Tighten the locknut to 55 ft-lb (74 Nm).
  8. Rotate fuel filter/fuel pressure regulator until its fitting is pointed to 10 o'clock position.
  9. Install the fuel tank.
Jul 17, 2010 | 2001 Jeep Wrangler
How do I replace the fuel pump on a F150 Ford truck and do i need any speical tools to do this
Things You'll Need:
  • Ratchet and socket
  • Wrench set
  • Floor jack and 2 jack stands
  • Ratchet extension
  • Fuel tank sending unit wrench number 310-123
  • Screwdriver
  • Slip joint pliers
  • New O-ring seal
  • Clean engine oil.
Steps to replace fuel pump:
  • Detach the splash shield from the frame rail located underneath the driver's side door. Use a ratchet and socket.
  • Unplug the electrical connector you will see after removing the splash shield. The connector leads to the fuel pump module.
  • Start the engine and let it idle until it stalls. Then crank the engine for about 5 seconds to relieve the remaining fuel pressure from the system. If the engine does not start due to a bad fuel pump, crank the engine to make sure fuel pressure is relieved.
  • Turn the ignition key to the Off position.
  • Disconnect the ground, battery cable from the battery using a wrench.
  • Jack up the rear of your F-150 using a floor jack and support it on 2 jack stands.
  • Remove the tank shield if your particular model is equipped with it using a ratchet, ratchet extension and socket.
  • Support the fuel tank with the floor jack.
  • Disconnect the straps holding the tank to the truck's body using the ratchet, ratchet extension and socket.
  • Lower the fuel tank just enough to gain access to the fuel lines, vapor lines and fuel pump electrical connector on top of the tank.
  • Disconnect the fuel lines and vapor lines from the sending unit/pump module. Press the lock tabs on the lines quick connectors and carefully pull the lines from their fittings. Then unplug the pump-module electrical connector.
  • Release the sending unit/pump module by turning the lock ring counterclockwise using the fuel tank sending unit wrench 310-123 or equivalent. See the Resources box and Tip boxes at the bottom of this article for more information.
  • Lift the sending unit/pump module off the tank carefully and discard the O-ring seal underneath the flange of the module.
    Install the Fuel Pump
  • Remove the old fuel pump from the module using a screwdriver and a pair of slip joint pliers and install the new pump on the module.
  • Lubricate the new O-ring seal with clean engine oil and lay the seal on the fuel tank opening.
  • Install the sending unit/pump module in the tank and turn the lock ring clockwise using the fuel tank sending unit wrench.
  • Lift the fuel tank just enough to attach the fuel lines, vapor line and plug the pump module electrical connector.
  • Raise the fuel tank to set it in its mounting place and secure the tank straps using the ratchet, ratchet extension and socket.
  • Install the fuel tank shield using the ratchet, ratchet extension and socket, if you had to remove it.
  • Lower your F-150..
  • Connect the ground, battery cable using the wrench.
Dec 05, 2009 | 2004 Ford F150
How to replace my 2001 ford taurus fuel pump Instructions
2001 Ford Taurus V6-3.0L DOHC VIN S
Fuel Pump: Service and Repair
REMOVAL
1. Remove the fuel tank.
2. Clean the area around the fuel pump mounting flange.
3. Using the special tool, remove the fuel module retaining ring.(Screwdriver and hammer)
4. Remove the fuel delivery module from the fuel tank.
CAUTION: The fuel delivery module must be handled carefully to avoid damage to the float arm, filter, and convolute hoses.
INSTALLATION
1. To install, reverse the removal procedure.
NOTE: A stop should be felt when aligning the raised arrow on top of the fuel tank delivery module to the dot on the fuel tank.
Sep 08, 2009 | 2001 Ford Taurus
2004 Dodge ram diesel just die out of the blue.
It sounds like it could be the transfer pump. Turn the key on and then crank the engine for about 1 second but leave the key in the run position and listen for the transfer pump to run. It should run for about 15 seconds after you stop cranking. If not, then you will need to replace the transfer pump with a in-the-tank conversion kit if your is mounted on the side of the engine block below the fuel filter housing. If you already have the in-the-tank pump then it might be siezed or the "sock" might be plugged up with alge or other contaminants. I usually lift the bed rather than removing the tank to replace the fuel module. If the check engine light is on you might want to have it scanned for codes to make sure since the modules can be spendy.
Jun 05, 2009 | 2004 Dodge Ram 2500
Need directions on replacing 2000 dodge durange 4.7 ltr fuel pump
WHAT YOU WILL NEED TO DO FIRST IS JACK THE TRUCK UP AS HIGH AS SAFELY POSSIBLE.. BE SURE TO USE JACK STANDS THAT WAY THE TRUCK DOENT FALL OVER.. ONCE UP IN THE AIR HE WILL NEED TO TAKE THE GAS TANK OUT OF THE TRUCK.. THERE ARE TWO STRIPS HOLDING THE TANK INTO PLACE..THEN WHEN HE GETS THE TANK ON THE GROUND, REMOVE ALL THE FUEL LINES.(THERE ARE CLIPS ON THE PLASTIC LINES BE EASY) THEN WHEN HE GETS THE LINES LOOSE, THERE IS A METAL RING ON THE TOP ON THE FUEL TANK..HE CAN USE A SCREW DRIVER TO GET THE RING OFF( HE WILL SEE HOW TO TAKE IT OFF WHEN HE LOOKS AT IT) WHEN THE RING IS OFF PULL THE FUEL PUMP ASSEMBLY OUT OF THE TANK AND REPLACE THE FUEL PUMP (THE WHOLE FUEL PUMP WILL JUST NEED PULLED OUT, NO SCREWS) ..JUST REPEAT THESE STEPS BACKWARDS TO REINSTALL .. THIS SHOULD SOLVE YOUR $700 PROBLEM..GOOD LUCK AND THANKS FOR USING FIXYA.COM...KEITH..
Mar 14, 2009 | 2000 Dodge Durango
Baby Gear Logo
128 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
