Question about Kenmore 54501 Dehumidifier
Kenmore 35pt dehumidifier won't stay on - Kenmore 54501 Dehumidifier
Won`t turn on
Dust. See if you can open the unit and blow some compressed air in the unit, trying not to touch any wires. Smell the unit to detect something that might have burnt after reconecting again after such a long time.
Jun 08, 2013 | Kenmore 54701 Dehumidifier
Kenmore 54341900 dehumidifyer compressor stays on too long and freezes up. humidity control is rusted up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 10, 2011 | Kenmore 54351 Dehumidifier
My kenmore 5949 dehumidifier is not lowering the humidity in my basement. The unit is on and the fan is running, but the humidity stays at 99 percent.
Is the water tank filling up? That will verify that the unit is really functioning normally. If so, is it possible that outside air is infiltrating the space?
Aug 08, 2011 | Kenmore Dehumidifiers
My Kenmore Dehumidifier wont turn on. There is power to it ,all the indicator lights are on, it just wont start. What's wrong?
Check the over fill switch in the tank. If this is stuck it thinks the tank is full and won't come on. After that your compressor may be bad or the starter for the compressor. The Dehumidifier is basically a small air conditioner that condenses moisture in the air then it drains into the tank.
Jul 13, 2011 | Kenmore Dehumidifiers
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
My dehumidifier is not working. The control panel lights-up, but its stuck on 70% humidity and won't adjust down. I took it apart and noticed burnt marks next to the circuit that controls the humidity....
I'd say you're right on target. In which case, although the unit was manufactured my Whirlpool for Sears under their house brand, Kenmore. You can find the part(s) online at Sears Parts Central
http://www.searspartsdirect.com/partsdirect/index.action . If you can do the replacement yourself, you'll really save $$ on labor.
Hope this helped you. Please let me know. Thanks.
May 30, 2011 | Kenmore 54701 Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
I have a model 54701500 and the bucket full light will not go off. I have bypassed the switch and the light still stays on, any ideas?
heatman101
Feb 24, 2011 | Kenmore 54701 Dehumidifier
I have a Kenmore dehumidifier model 580 -54501 it will not stay on. goes on but flashes 01 on the screen.
For sure this is an error and could be a fault in the heater panel or the motor drive.
Must remove out and check if the fault goes off on disconnection of one of the above.
Sep 28, 2010 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
