Question about Belkin (F5D7231-4) Wireless Router
It wont connect
When i press connect it just says there is no dial tone and the internet doesnt light up at all.
  • 2,961 Answers
If you have reset the router for any reason, you must have the incorrect settings eg PPOA PPOE or you have not entered the correct password and username. It is also possible that your broadband connection to your isp server is down. On the other hand if you have installed this modem/router in place of a dial up modem or a broadband modem, your modem is still trying to connect, which needs to be dissabled as when you use a router you do not have to click connect unless you are in the routers settings as you are always on line, unlike a dial modem, so you should have uninstalled the modem driver. If you have just installed the router you need to open up internet explorer>tools>internet options>connections and choose never dial a connection, unless its all greyed out, in whicj case you need to go back into the router and check the settings.
Posted on Sep 01, 2007
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
How ican send a fax with samsung scx-4521f?
first you connect the telephone port to your machine and telephoe line.
.then load your fax document to ADF. then their is a button in your machine its name ON HOOK DIAL .press it then you can here some dial tone. press fax number if you wont to send. then you can here some ringing tone and press start button after fax tone coming.
Jan 12, 2011 | Samsung SCX 4521F All-In-One Laser Printer
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
No dial tone no incoming calls or outgoing calls
Have You Tried Replacing The Cable Connecting the Base To the Wall Jack? If Not Do That...
If that doesnt work there should be a channel button on the handset try that...If that doesnt work i would say the handset itself is bad.
Apr 03, 2009 | Uniden Cordless Phone EXAI985
Telephone has a dial tone but cant dial out
talk with a technician about a problem phone line filter for the internet
it is possible that it has failed and the adsl and phone frequencies are giving a problem to the phone operation
Apr 21, 2017 | Vtech Lands Phones
There is no dial tone" in LG Internet Cube
i have tried the same thing and the dial tone has failed but i think you might have to have credit on your phone to do it but i'm unsure to cause mine won't work
Jan 04, 2008 | LG KG800 Cellular Phone
Belkin (F5D7231-4) Wireless Router Logo
80 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
