Question about Franklin Merriam Webster DBE-1450 Dictionary/Translator
I do not remember how to change the resolution on the screen from dark to brighter.
I have a technics PR-305 Digital piano, the LCD Screen back light has gone dark Is there anyway of fixing it to make it brighter or would i have to forget about it?
If I am not mistaken, it has a small light built into the area that may have to be changed. Check with Radio Shack for the light, or Amazon.
Jul 26, 2014 | Technics Audio Players & Recorders
Acer laptop screen is dark an will not brighton l
I would like you to try 2 things:
1. Press and hold the blue Fn key then press the right arrow key a few times and see if it gets brighter. If that doesn't work try #2
2. Press and hold the blue FN key then press F5 or F6 not sure which one changes your screen. If it seems to mess something up it's ok. Just press the same combo that messed it up once or twice and it will go back to normal.
Please comment and let me know if it worked! :)
Apr 10, 2013 | Acer Aspire 3690-2196 Notebook
Side screen brighter
There is couple of factors. Most probably that is a problem with your laptop's "CCFLbacklight" or "inverter board". googling with these two terms will let you know more about the problem. If its a CCFL problem then you need to change the whole LCD screen. A skilled tech can change the CCFL but touching the polarizing film will give you dark faded spots in the LCD screen. So it is a good idea to change the whole screen. Best option is to check it with a skilled technician. Hope this helps.
Dec 01, 2012 | Acer Aspire 3680 Laptop
The time display is dark. the radio works and I can set an alarm but the time display is dark. I seem to remember there is a battery somewhere that may need to be replaced.
it may be that the display died or it not getting enough light on the screen because it has a senor that when the lights turns on it will be brighter or if this does not work call bose at 973 644 BOSE
Jul 10, 2011 | Bose Wave Radio
Hi! I am experiencing difficulty with the brightness on the screen of my GameBoy Color. Is there a way to adjust the screen brightness, so that it would be brighter? -Stine
Unfortunately, the Game Boy color has no backlight, so there's no way to make the screen any brighter. You can change the contrast, but that will only affect how dark things appear on the screen. Sorry.
Mar 16, 2011 | Nintendo Game Boy Color Console
Screen is very dark. how do i make it brighter
You can adjust the power options (power save/ economy mode) settings and also the display settings in your control panel.
May 12, 2009 | Acer Aspire 5630 Notebook
Screen resolution
HAVE you tried the key Fn along with the key that marked brightness sign togehter
Nov 11, 2008 | IBM Computers & Internet
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Franklin Merriam Webster DBE-1450 Dictionary/Translator Logo
Top Franklin Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Michael Vincent Cruz
ray gallant
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
