Question about Huffy Cycling
Huffy rock trail 10 speed mountain wont shift
  • 1137 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: need a bearing size or
Pedal bearing or bottom bracket bearing? Your best bet would be to take it to a local Bike Shop and have them assess it.
Posted on Aug 05, 2010
Testimonial: "Thank you"
SOURCE: How to raise the handlebars on a 20" Huffy Rock It
Usually there is a hex bolt or some kind of bolt in the handlebar stem.
Loosen the bolt 4-5-6 turns.
Bolt will move upward.
Then hit bolt down with wrench.
Handlebars should be loose.
Raise handlebars to position.
Hold bolt upward with fingers while tightening.
Posted on Dec 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: with the handle ajustments
Adjustments
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Use
http://www.sheldonbrown.com/gears.html
Wear a helmet, ride as you would drive a vehicle, obeying the laws.
Posted on Feb 19, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Huffy Savannah
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look straight along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
THERE IS NO UPSIDE TO CROSS-CHAINING.
As you can see, the rear derailleur is probably not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
Ancient bike wisdom for beginners: If your legs ache, shift down. If your lungs ache, shift up.
Posted on Apr 25, 2011
What is the replacement pedal bearing in a huffy mountain 24" bike?
at the Huffy quality level of pedals, you most likely won't be able to service the part, you can find a set of replacement pedals at your local bike shop starting at about $10 for the pair.
Apr 28, 2014 | Huffy Cycling
I just purchased a second hand 10 speed 26" Huffy bike and need to know how to work the gears
Web search "how to shift gears" and go to http://www.huffy.com/Support/OwnersManuals.aspx for there generic manual.
The web has all thwe answers. Just ask it.
Aug 12, 2011 | Huffy Cycling
I have a dynacraft magna great divide 21 speed mountain bike and don't know how to use it. There was no owners manual. I don't know anything about using the gears, could you please help'
Bikes is bikes so ANY owers manual would ge tyou through the basics.
TRy Huffy's. http://www.huffy.com/Support/OwnersManuals.aspx
Then, using a search engine, ask any question like "how to shift a bicycle" and videos will appear instantly.
This doecument will teach you a whole bunch of stuff about techniques and strategy for road riding.
http://www.johnforester.com/BTEO/ECIL.pdf
Jul 03, 2011 | Cycling
Need a bearing size or part number to replace a pedal bearing in a huffy stone mountain multi speed 26" bike
Aug 04, 2010 | Huffy Cycling
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
Jul 13, 2010 | Huffy Men Mountain Bike (26")
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
Operator manual for huffy crosswind bike grip shift
Jul 15, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Cycling Logo
44 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
