Question about Dishwashers
SMEG integrated dishwasher (type 12043, Mod. DWI612C not stopping
COXY
  • 76 Answers
SOURCE: SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Posted on Nov 18, 2007
  • 120 Answers
SOURCE: Smeg integrated dishwasher continually washing -
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Posted on Nov 03, 2009
  • 3600 Answers
SOURCE: SMEG DWI612C WON'T PUMP WATER OUT
even if the pump is running does not mean the impeller shaft is turning, You could unplug the machine and disconnect the washer and pull out and drop the hose to see if water will drain when you lower the hose to about 8 inch's does it run out freely? if not check for a plugged water pump or water pump hose if the water flows freely you will need to drain the washer if it's on rollers roll it out side to allow the water to drain out the machine from the porch. while it is draining check the hose that the washer connects to see if you see any plug in the pipe. put the sink drain plugs in and fill half way with water put a bucket under the sink after filling the water to half full pull the stopper out of the sink that connects to the dish washer. Hold your hand on the hole of the connection to the sing watch to see if the drain allows the water to flow. If it flows freely you can assume that the water pump is bad. If thats the case it's best find someone to replace the unit the pump can be replaced but you need tools to do so and you did not state if you had any. thanks for using fix-ya.
Posted on Apr 18, 2010
michael_p_pi
  • 112 Answers
SOURCE: how do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Posted on Sep 02, 2012
  • 16 Answers
SOURCE: Integrated Smeg dishwasher keeps stopping and starting with a beep every few seconds. Tried switching off at mains, filling salt
Try pushing on the door, to see if the stopping/restarting stops, I am guessing your door switch may be wore a bit, and maybe out of adjustment when closing. sometimes the mounting hardware slips out of place, and the door switch in not engaging enough to stay on.
Posted on Dec 19, 2012
Are air compressors and air tanks that are contaminated with PCBs <50 ppm regulated for use?
PCBs in air compressor systems are authorized for use at concentrations <50 ppm. http://www.qjpcb.com/ whatsapp:+8618688621379 http://www.qjpcb.com/
Oct 06, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
Is notification to EPA for PCB research and development under §761.30(j) still required?
No, notification to EPA is not required under ยง761.30(j). However, notification is required for research and development for PCB disposa http://www.qjpcb.com/ whatsapp:+8618688621379 http://www.qjpcb.com/ Skype : wang.michelle35
Sep 22, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
If a spill occurs from equipment assumed to be PCB-Contaminated, can I assume that the spilled liquid contains a PCB concentration of 50 and <500 ppm?
No. The PCB concentration assumptions apply only to equipment while in use, not to material spilled or otherwise released from the equipment.
Sep 14, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
How do PCBs get into natural gas pipelines?
Polychlorinated biphenyls, banned in the U.S. since 1979.
Some residue is probably still in there.
Printed Circuit Board (PCB) is something totally different.
Sep 08, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
Smeg DWI612C not ending a cycle- it goes on for hours
Sounds like your Dishwasher may not be heating. If this is the case then it maybe the heater itself or one of the thermostats
Feb 03, 2013 | Dishwashers
How do i fit smeg integrated smeg dishwasher
Sep 02, 2012 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
