Question about Canon PIXMA MP150 All-In-One InkJet Printer
What does an ink absorber look like - Canon PIXMA MP150 All-In-One InkJet Printer
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
Mp510 waste ink needs emptying
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 22, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Ink absorber full
Ink Absorber Full
Jan 19, 2013 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is almost full on Pixma MP110-how do I clean?
Ink Absorber Full
Jan 19, 2013 | Canon PIXMA Office Equipment & Supplies
How to solve the problem canon ip 3680 ink absorber
Ink Absorber Full
Jan 11, 2013 | Office Equipment & Supplies
Where are the "ink absorbers"?
Ink Absorber Full
Aug 19, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
Aug 19, 2012 | Office Equipment & Supplies
Canon mp180 ink absorber full
This mayclear the ink absorber problem.There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
May 31, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Canon ip3500 series the ink absorber is full contact the service center
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
Aug 07, 2011 | Canon PIXMA iP3500 Printer
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Mar 31, 2011 | Computers & Internet
Canon PIXMA MP150 All-In-One InkJet Printer Logo
64 people viewed this question
old marine
old marine
