Question about Weiser Lock Powerbolt 1000 Lock
Parts worm pinion 4910-016-70 Sears radial drill press
  • Mel Wallace Aug 03, 2013
    Want to purchase a worm pinion part NO. 4910-016-70 for a Sears 34 inch Radial Drill Press Model 149.213340.
Where can I get the users manual for a Craftsman drill press 113.24520
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support.
Apr 26, 2016 | Craftsman Drills
I need a key for the shop fox w1669. where can i get one. Thanks, Doug
Your drill press uses a 5/8" JT33 drill chuck. Call a local hardware or tool repair shop and see if they can get you a key for that model chuck. You may also find one online but the shipping cost would probably be more then the key.
Jul 16, 2011 | Woodstock International Shop Fox W1669...
I need a fine threaded screw that goes into the bottom of the drive that holds the drill bit chuch in place on my radial drill press model # 149.21334. I don't have a manual or a part number. Thanks.
this chuck doesn't have a chuck retaining screw, it is a taper fit. Go to Managemyhome.com and type in your model number adding a zero after the last 4 and you can download a breakdown/manual for this unit and it shows how to reinstall the drill chuck. Let me know if you need more assistance and if I have helped you would you please rate this response accordingly and thank you.
Feb 13, 2010 | Craftsman Drills
I just bought a Sears radial arm saw. Model
Go to searspartsdirect.com and list the model number which brings up drawings of all parts and usually a manual. Hope this helps!
Feb 05, 2010 | Saws
Broken elevating rack
Please contact your manufacturer for parts. FixYa.com dispenses advice ... not sell parts.
Thanks for your question
Jan 20, 2010 | Shop Fox W1670 1/2 HP Floor Radial Drill...
Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
Oct 20, 2009 | Drills
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not printing at all. Screen appears as series of exclamation marks
I had the same problem with my label marker. Changing the batteries fixed the problem
Jan 08, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Weiser Lock Powerbolt 1000 Lock Logo
52 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
