Americool WAM18 Single unit (heat/cool); operates perfectly well except that lately it started displaying an E5 error code every now and then and naturally stops cooling. Switching off and ON again generally clears the problem, but sometimes it will stop again for the same flashing error code E5. When it runs well, it really cools fast and is very efficient; has been installed since 2000 (13 years, yes!) - never had problems before this one.
pierre1811
  • 144 Answers
SOURCE: Armstrong 4PHP13E36P runs after heating element cools
There may be pins on the circuit board inside the air handler that you can adjust. First turn off the breaker then look inside at the board. They may say 30-45-60-90 etc. Put the pin on a lower number. Do you have a digital or programmable T-stat? There may be a setting in the T-stat setup program that allows for blower delay also. consult you installation instructions. Last if the blower isn't turning off at all then the relay on the circuit board is stuck closed and should be replaced.
Posted on Mar 10, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
meBNme
  • 334 Answers
SOURCE: My ac unit works sporadically. Today it cooled
First check your filters to make sure they are clean and you have proper airflow.
If they are clean, then you either have low refridgerant or dirty coils.
The outside coils can easily be cleaned by disconnecting power to the unit, then using a water hose to spray off the dirt, grass, etc.
The inside coild can be very difficult to get to on some units and require a special evaporator coil cleaner. As for adding refridgerant, the Law requires one to be certified for purchasing or working with refridgerant so you may need to call a service tech for that. Expect a bill from $100 to $225 for a typical system recharge depending on how low it is and which company you call.
Posted on Oct 10, 2009
Sea Breeze
  • 4655 Answers
SOURCE: units runs but cool air will stop even thou blower...
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: i have a a/c unit mitsubishi electric ms-12rv r22
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
Midea Tower AC show error E5
Midea Error Display = E5
Error Code Definition = Open or short circuit of outdoor temperature sensor
Apr 03, 2017 | Midea Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
