Lg dvd player dv 482
Can i use lg dv582 rc 0n lg dv482
worldvet
  • 859 Answers
SOURCE: unlock code for dvdplayer LG RC 195
You may want to copy and paste this into notepad or another writer program, save it and print it so you have it in hand and have read and understand the sequences as they are rather involved for your player.
This is from VideoHelp.com
[quote]
Turn on TV and player, press home key on player remote; in setup, scroll down to the padlock icon (when you get to the "padlock" option on your remote, leave it there, don't go to the menu to the right which has three options--rating, password, area code. Leave it on "lock", press 0000000 and you will be region free.
[close quote]
That's seven zeros.
If the above sequence doesn't work try this other process below.
[quote]
Press the HOME button on the remote, go to Setup and select Start. From the TV options go to TV Aspect and highlight the 16:9 Wide option (must be 16:9 0ption). Now enter 1397139 using the number keys to access the system configuration information.
To change the values of these options hit the ENTER button and then use the left/right arrow keys to select OPTION 5. Change it's current value to ff using the up/down keys. Now power off with the remote and then power back on. Your recorder should now be region free. To check go back into the system configuration information where Region Code should now be 0
[close quote]
Regards,
Worldvet
Posted on Jun 08, 2008
jaffa012001
  • 376 Answers
SOURCE: open regional codes
Using the remote control open tray
Press 0, 0, 0
Region selection will appear.
Select 0 for no region (ie. all regions)
Press pause button on remote control.
Turn Unit off and back on again.
It should now be region free.
Posted on Sep 08, 2008
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
SOURCE: ny dvd player doesn't read any dvd's, it makes an
You have two options. One buy a replacement deck that will only take a phillips screw driver and about ten minutes to swap out or buy an LG IDE pc drive and swap out the lens. The first option will cost anywhere from $ 30 to $ 200. The second will cost from $ 10 to $ 20 but takes about 20 minutes to swap out the laser unit. I always do the second option. You can use any LG pc drive with the numbers GSA-H**n or GSA-41**b. I used GSA-H10n and GSA-4165B but you can buy any pc drive except those with the letter "L" which designates LightScribe. Those units don't seem to work. When you swap out the laser you may have to use the circuit board in the pc drive but that's also easy to exchange.
Posted on Feb 07, 2011
  • 146 Answers
SOURCE: What do we do if
try firmware update
make sure movie you are watching is legitimate copy and not bootleg which usually do not work
firmware can be updated right through unit if it has internet connection on it otherwise you will need to contact manufacturer and get an update on disc set to you
Posted on Mar 13, 2011
MY LG DV582 DVD HAS NO PICTURE BUT HAVE A SOUND
Mother board faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 07, 2016 | LG Televison & Video
Lg dv582 dvd switched on hd and now got no picture how do i restore it.
You have to reset the unit:
1. Remove the disc in the unit.
2. Press and hold "STOP" for five seconds. The video output will be restored to the standard setting, and a picture should be visible on your TV.
Jul 06, 2014 | Televison & Video
Kg dv582 accidentally switched on hd now cant get any pictures how do i restore it.
I think you mean LG dv582.
Reset the unit:
2. Press and hold "STOP" for five seconds. The video output will be restored to the standard setting, and a picture should be visible on your TV now.
What do we do if it reads: Check regional code on the LG dvd player model DV582
try firmware update
Mar 13, 2011 | Televison & Video
I have never been able to play a slideshow 0n my dv454 no matter where i had the discs burned what am i doing wrong? ps the discs play in other dvd players
Check to make sure that the format of the discs burned are acceptable by the dvd player, some companies do not support certain formats. refer to owner manual as to which ones are readable on your particular dvd player. if the dvd player plays other regular/non-burned discs, this is the probable issue,...more info is needed if this is not solution.
best of luck
Oct 17, 2010 | Pioneer DV-454 DVD Player
LG RC-288 disc problem
You need to use CD/DVD lens clening disk. If wont help gently clean the lens with Q-tip and 40% vodka or 50-70% rubbing alcohol
Good Luck
Feb 21, 2009 | LG RC-197 DVD Recorder/VCR
LG RC388 AND PC DVD PLAYER
Finalize the disc within the on screen menu. That's it.
Feb 18, 2009 | LG RC-197 DVD Recorder/VCR
Onkyo DVD player - remote doesn't function at all
One of the two things might have happened:
- The IR sensor got covered - by some reason
- the IR sensor talks to a small controller back - which is not working at all.
Dec 17, 2008 | Onkyo DV-S525 DVD Player
Jan 20, 2008 | Onkyo DV-SP800 DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
