Mdn4rb4mrc panasonic fan motor - Audio Players & Recorders
Tip
Error code:H19 in Panasonic a/c
H-19 means Indoor fan mechanism lock, check fan motor bearing and replace or motor. If motor is good, Problem with PCB which not commands.
on Jan 11, 2011 | Heating & Cooling
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
My panasonic micro-oven is working but the fan and turntable are not operating.
HI.oven has a small DC motor thats turns the turnatable..Now if turntable does not rotate then yuo need to remove the bottom cover of the oven..Unscrew it and check if motor is working ..You can check continuity of the motor using a MULTITESTER..If it is short-circuited or not.Hope this helps.FAN and turntable is being run by this DC motor..Hope this helps.
Jul 14, 2011 | Panasonic Microwave Ovens
Panasonic Split system turns off all the time
May be your fan motor mechanism blocked. Open the cover and rotate blower motor manually. If it's struck, replace bearings or motor.
Dec 26, 2010 | Panasonic Heating & Cooling
My electric fan can turn on for a few second only. what happen?
mcdevito75 here, Sounds like the fan motor is seizeing. Check after the few seconds if the motor is getting hot, if so, the motor is seizeing, replace the fan.
Jul 26, 2010 | Panasonic Dryers
I have a Panasonic 1200 BTU air conditioner, that ...
The ball bearings in the fan motor is toast. Options: 1. Contact your dealer or Panasonic directly. This is a known problem and Panasonic will send you a new fan motor for free or at a reduced price, depending on the age of your unit. You will probably have to change it yourself, or call a tech to do it for you (about 1 hour of work).
2. Change the ball bearing(s) in the fan motor yourself. 1-2 hours of work if you are somewhat handy. Buy a CERAMIC bearing (Size 608, ZZ, Ceramic - the same size you use for a skateboard) @about 10 USD (7 EUR) in your local hardware store. You probably only have to change one bearing, the one on the "inside".
May 20, 2010 | Panasonic Room Air Conditioner CWXC104HU
Panasonic split system fan motor overheas
put the lubricants or grease motor bearings
Oct 10, 2009 | Heating & Cooling
 Grubhead
Grubhead
