Question about HP Pavilion Computers & Internet
I want to connect hdmi from my pavilion g6 intercore i5 to my ozzan 32'' lcd tv but no signal.and I check my intel utility it tells monitor/tv unsupported..even my intel driver is updated.
    Top Expert:
  • HP Master
  • 12,223 Answers
See the diagram attached.God bless you
I want to connect hdmi from my pavilion g6 - 59250b70-2a69-422f-8529-6d6bb31c3b8e.jpeg
Posted on Jul 31, 2013
SOURCE: HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Posted on Jan 09, 2009
tat4u
  • 520 Answers
SOURCE: connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Posted on Jan 29, 2009
leecom72
  • 4806 Answers
SOURCE: unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
  • 86 Answers
SOURCE: I am trying to hook up my hp laptop to my sony
"Unsupported Signal" means that your laptop is probably set to a resolution or refresh rate that yoru TV doesn't support. You will need to go into your Laptops video settings to make them match what your tv will display.
Posted on Jun 03, 2009
  • 691 Answers
SOURCE: Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Posted on Jan 08, 2010
Sony 32 inch TV keeps shutting down on BBC 1 ? why
Hi
at HDMI may be some signals are disturbing the tv at BBC1 so please try to change the HDMI setting if the problem goes then ok other wise you may connect your tv box through AV
Feb 14, 2015 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Thanks
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
32 Inch rca lcd dvd combo has no sound?
Try vith headphones or audio out on the scart .
Try with audio standard in menu options.
try with signal on scart or hdmi input with other source of signal like dvd or cabel recivers.
If there are no sound after this you have to check-replace the audio section in your tv.
Jan 28, 2014 | RCA L32HD32D 32-Inch LCD/DVD Combo HDTV
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
I am trying to connect my LCD Hi-def television to my computer so I can watch internet on my tv. The tv is showing "invalid signal". What is this and how do I fix it? I have the dynex DVI-D to...
You can only use your TV for viewing internet from your computer by using the TV as a PC monitor. To do this you should connect your computer to your TV using a standard VGA cable - the same as you would use to connect your computer to any other external monitor. You should note that this cable doesn't carry a sound signal so you can't use the TV speakers for sound output.
However, you can connect an HDMI cable from your computer to your TV to play media files or DVDs. This cable does carry a sound signal so you will be able to use your TV speakers here. This cable cannot be used for turning your TV into a PC monitor.
And all of above shouldn't be confused with "Internet TV". This is something totally different and requires your TV to be connected directly to the internet.
Hope this helps.
BElectric
Nov 07, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
Astar 32'' LCD - anyone have monitor drivers?
I purchased this model
http://www.newegg.com/Product/Product.aspx?Item=N82E16889114016
and have been able to get 720p and 1080i resolutions on DVI connections from my PC with both Intel and ATI graphics AND 1920x1200 resolution over VGA from the Intel integrated connection (the ATI has only DVI). You need to dump the EDID to see what resolutions and timings the TV is telling the video card it supports. Then you need to get a video card driver that allows for custom resolutions to be created. First download this free utility and post the output: http://www.entechtaiwan.com/util/moninfo.shtm
Nov 16, 2008 | Astar LTV-3201 32 in. LCD Television
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
