Question about Boston Acoustics TVee Model 20 Soundbar with Wireless Subwoofer - Black
Boston tvee model 20 no sound - Boston Acoustics TVee Model 20 Soundbar with Wireless Subwoofer - Black
  • 73 Answers
SOURCE: Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
Posted on Jan 21, 2010
  • 6 Answers
SOURCE: need the Boston tvee sound bar repaired. Making
The sound bar system was not adequately tested before release and it's obvious. The sub seems to disconnect and reconnect randomly. This also happens when the bar is off. It makes a large bassy pop every so often when it shuts down. It's woken me up at night when it decided to turn on and off. Occasionally I have to power cycle the sub or even change the frequency in order to re-establish a wireless connection. All of this is an occasional occurrence and poses more of an annoyance than anything. It's crappy to have to say that "It works most of the time." It's too bad because the concept is fantastic, and now I question the quality of Boston Acoustics.
Posted on Feb 21, 2010
SOURCE: hello, my boston acoustic TVee
mine is doing the same thing. have you found a fix for this?
Posted on Dec 26, 2010
  • 2246 Answers
SOURCE: boston tvee doesn't work
check cable power and check cable connection
Posted on Jan 15, 2011
SOURCE: I have a TVee model 2 from Boston Acoustics
Hi jdmowen,
I see that you need help since you lost the hardware for setting up you TVee Model Two Speakers.
What hardware are we speaking of? check the links I have provided, one of the links will be the manual and the other links will be where you can get the parts that you might need.
Manual
Parts Boston Acoustic Website
Parts Reseller
Parts Other Resellers
I hope this will help.
send me a message if you need a specific part maybe we can get info for it.
mvincentc
Posted on Jul 04, 2011
Cannot get sound out of TVee 10
Try pressing the function select button to change inputs.
Dec 28, 2012 | Boston Acoustics TVee Home Theater...
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Boston tvee doesn't work
Jan 15, 2011 | Boston Acoustics TVee Model Two TV...
Need the Boston tvee sound bar repaired. Making popping and cracking noise when power is on.
Haven't fixed it yet. Going to find a electronics repair shop locally and have them repair it.
Thanks.
Apr 11, 2009 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Model 20 Soundbar with Wireless Subwoofer - Black Logo
29 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
