Question about Sewing Machines
Pfaff hobby 1020 keeps bunching up bobbin thread
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
SOURCE: Bobbin thread bunching
I have a Kenmore 16231 That kept bunching up on the bottom side of the material. I found to correct this problem, there is a tension adjustment under the cover on the left side of the machine ( the light is housed under this cover) I found a tensiner lever numbered 1 - 4 and if you try this adjustment on 3 or 4 this machine works great. hope this helps
Posted on Jan 05, 2009
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Aug 16, 2012 | PfaFF Sewing Machines
While I was sewing the machine stopped properly threading, so I tried rethreading and checking bobbin tension, but it looks like the needle is just not reaching the bobbin, so it is missing the bobbin...
Have you changed your needle? If so do a visual check on the bobbin case area.
-With the bobbin door open, so you can see the bobbin case, turn the hand wheel towards you and you should see the needle come down and the top thread catch and loop around the bobbin thread and pull both to the top.
-If if is not, it is going to be your hook to needle timing or clearance.
When the needle is on the up movement, the hook should pass right above the eye of the needle.
-Chris
Jun 08, 2010 | PfaFF Sewing Machines
How to adjust lower tension on pfaff hobby 370
On the bobbin case is a screw. Mark the case with a tiny dab of nail polish and the edge of the screw. This will tell you where you began.
Turn the screw: right to tighten and left to loosen.
This is an adjustment that is usually not needed unless you are changing the weight of the thread being used on the bobbin.
Mar 12, 2010 | PfaFF Sewing Machines
The top thread is not picking up the bobbin thread
Check the timing of the needle to the hook. HERE is a guide to generic principles of Timing
Best Wishes Martyn
Bargain Box in Australia
Sep 08, 2009 | PfaFF Hobby 4260
How to thread a phaff 301 hobby
hi there,
9e43374.jpg this your sewing machine,well if you to learn more on internet explorer type the address of www.youtube.com the on search box type sewing machine. there a lot slide show to start sewing you can choose how to thread and wind bobbins and lot more.happy learning whli enjoy watching.
regards,don't forget to rate me and log in to fixya will serve you better. thank's
ps. if you want manual Download the HOBBY-301-420- Pfaff sewing machine manual: http://gotoes.org/sales/PfsffSewingMachineManuals/ViewInfo.pl?Paff=1&Sewing_Machine_Model=HOBBY-301-420-INSTRUCTIONS
Apr 09, 2009 | PfaFF Sewing Machines
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
May 20, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
