Question about Honeywell Enviracaire 17352 Air Purifier
Can't turn it on -- need manual
My dad had this thing working today, but now I moved it into my bedroom, plugged it in and I can't get it to turn on. There must be a trick. Battery is good, screen working, can't turn on the filter. Please help!
You need to change the battery on it; once the battery dies, the filter will not turn on,
Posted on Jul 03, 2008
Give it away! Seriously. I put it in the garage to throw out, my mom came and was willing to give it a try. Even though I couldn't get it to work it performed like a charm for her! LOL!
Posted on Jan 05, 2008
I am having this same issue on my honeywell 18155. it worked great for a few days and then just quit turning on. Any suggestions? Fuse? Thanks!
Posted on Jan 03, 2008
You have to plug the unit into the wall directly and not to a power strip or UPS. Then just choose the speed for continuous filtering.
Posted on Oct 22, 2007
I bought the big Idyllis -awesome;however, I purchased a second and it was possessed - makes woooo noises. exchanged it. Same thing. Smaller unit -loud. Would like another large with the wooooooo.
I used to use a damp papertowel and then an antiseptic wipe or spray a tiny bit of windex on a second paper towels and wipe each bar individually lts just a pain and a bit scary. this way it should be left to dry for hours. the dust is connecting the ionic filter the metallic bars that look like the bottom of a DVD are statically connecting creating the pop noise a shaking or rattling noise means it probably wet.
I got a trick use a microfiber towel to wipe the majority of the filters filmy residue. then grab a screen cleaner used for a tablet I pod or a cell phone. once the icky sticky collection on the ionic filters metallic bars. the cell screen cleaner. should make all the metallic parts oil and dust free. and they can be used over and over again. a microfiber towel just needs to be rinsed by hand afterwards if it's dirty it's fine it's just used so that there's no papertowel remnance. a glasses lense cleaner should just get the oils off afterwards cause that will make it so it won't attract dust quicker which is how it shakes wen wet. Basically tiny dampness attracts dust creating a clumping which makes it unbalanced so then the shaking or rattling. u gotta start over again. those are two ways.
now afterward take a deep breath plug it in hold the button down for 3 to 5 seconds. This should reset the switch to normal and then press it again to turn it on. it should only have a tiny breese. My dad would say that it's broken but it's for allergens and free flowing dust. So have it a foot off the ground and usually near a light switch cause they never have furniture there also all switches are out of the way cause usually the first thing you need to see is light which is why ur hand reaches not ur feet as if u would kick first to find a couch. if you have it by the couch or chair it my seem plesent till it falls. all purifiers r the same an ion charge stimulates low electricity attracting fibers or dust as a balloon gathering static electricity. the best purifiers to have are the water filtering purifiers no problems there just change the water once a week. well I hope you got some knowledge of helping you understand how and why they do as they do. most people end up giving them away.
Jul 03, 2015 | Air Air Purifiers
The machine seems to be working, but I am not getting the same clean smell I use to. I have a bedroom closed up with an old mattress that smells of cigerette smoke, usually this sort of thing is no problem...
Check that the purification plate contacts and associated wiring are clean and make good contact with the plates. Also check the plates themselves for dirt build up on the metal grid. If the plates are a few years old, they should be replaced. Your dealer should be able to help you get new plates. Leave a comment if you need additional help.
Sep 02, 2010 | Ecoquest Breeze AT Living Air Purifier
Cleaning Fresh air 2.1
I can help you get a copy of the manual. I can either fax or email it to you. If you email me, I can send you a copy. My email is stevelam at
Feb 12, 2010 | Ecoquest Fresh Air Air Purifier
My Sharper Image Ionic Breeze, model 51737worked fine but when I turned it on today it wouldn't work. What could the probelm be?
those things are not worth a bit. you should throw it away you could even possibly be causing yourself more indoor air quality problems by running one with the amount of ozone they produce and put into your home. throw it in the garbage.
Sep 12, 2009 | Sharper Image Air Purifiers
Xl-115 Automatic setting not working?
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
Sep 08, 2009 | Ecoquest Living Air Classic Air Purifier
This air purifier has not reduced my allergy symptoms.
You are a ***** and need to get outside more ;-)
Dec 03, 2008 | Ionic Pro TURBO Air Purifier
Pure-Ion not working?
Didja wash the plates? It takes a little maintenance, and there are a lot of things that could make it stop working (Magnum, anti-aircraft fire, someone tripped over the cord, power quality in Karachi is lousy, there's pudding in the works...) but washing the plates with dishsoap and water, (then drying them before trying to start again) ought to fix most things that could be wrong.
Sometimes a fiber (a gift from a guest, maybe) is protruding into the works that needs to be removed, but those are the main reasons.
Jun 20, 2008 | Brookstone Pure-Ion UV Air Purifier
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude!
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Honeywell Enviracaire 17352 Air Purifier Logo
339 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
