Question about Yamaha RX-V673
Yamaha RX-V673 sound goes off for a couple of seconds
5 Suggested Answers
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
aparsons89
  • 40 Answers
SOURCE: problem with yamaha rx-c2092
Hi, try to unplug this unit from the wall for a minute or so, It may just need reset. If it still does this I would say that you have a loose wire inside where the power supply is. I would not recommend working on this unless you are computer savvy.
Posted on May 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: yamaha reciever rx-sl100 comes on
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
  • 1054 Answers
SOURCE: IS YAMAHA AMPLI RX SERIES RIPP OFF
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
Posted on May 21, 2013
Testimonial: "Speaker tested ok .According a french forum problem is coming from weak tension caused by cheap cheap components provided by yamaha . It s a shame. thanks a lot for your help"
My RX- V673 Yamaha receiver won't turn on. I have power and the stand by switch is on
Try holding the 'tone control' and 'info' buttons and press power. This will unlock it if it is protect mode. If it turns back off right away, then you most likely have a problem in the amp circuit which needs to be repaired.
Jan 17, 2017 | Yamaha RX-V673
Power led blingking
First, try holding down the Main Zone power button for more than 10 seconds in order to initialize and reboot the unit. If that doesn't work, I think a visit to the local Yamaha service center is needed.
Mar 15, 2014 | Yamaha RX-V673
Total did
need to know if it comes back on when you turn it on again, even for a few seconds ?
Jan 06, 2014 | Yamaha Audio Players & Recorders
Receiver does not respond to remote, will not turn off or on with the remote what is wrong?
Dear sir my name prakash my won us Yamaha AV Receivers Model RX-V673 Go To died mode what this problem please sir?
Jan 06, 2014 | Yamaha HTR-5730 Receiver
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Yamaha Receivers have International Warranty?
Just send an E-Mail to Yamaha's customer service section. I'm certain they will be able to tell you.
The only other problem you might encounter is if the USA model uses a different mains system to the one in Brazil.
Jun 01, 2013 | Yamaha RX-V673 7.2-Channel Network AV...
My sub wont power off when I turn off my Yamaha RX-V673
The sub would have to be getting AC power from an outlet on the Yamaha
Jan 08, 2013 | Yamaha RX-V673
Yamaha RX V673 airplay problem
Disable IGMP filter on your router
Nov 13, 2012 | Yamaha RX-V673
Yamaha RX-V673 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
