Question about Refrigerators
Dometic rm 2201 what is the 110 volt heating
Dometic rm 2201 what is the 110 volt heating element part number?
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Posted on Feb 13, 2009
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
  • 10 Answers
SOURCE: trying to purchase a heating element for a Dometic Dm2652
Try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673. there not a dealer just a service department, they might be able to help.
Posted on Feb 16, 2010
  • 230 Answers
SOURCE: replacing heating element on dometic frig and old element is stuck in tube
The tube should be held in by a couple of clips if it is not then you will have to unscrew the evaperator to be able to maneuver the heater out on the tube. The heater is flexable but don't bend it too much. Good luck
Posted on Sep 08, 2012
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Dometic RM 2862
remove heater element from back board if ok bad heat element if ok disconnect ignitor if ok replace ignitor if not shorted wire or bad board
Jan 13, 2014 | Dometic Americana Plus - 8 cu ft DM2862...
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
Not working on 240 volts ok on 12 volts
The Dometic brand use separate heat elements for the different voltages. The heat elements are located in the back right hand corner (looking from the rear) about 6 inches up from the bottom. You will see 4 wires coming from the box, 2 for each element. They may be marked which is for each voltage, but if not an ohm meter will be needed to see which one is bad.
Apr 18, 2010 | Dometic Refrigerators
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
