Fe & oe problems on lg f1222td washing machine
Overfills will drain water but oe comes on and will not spin
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have a problem with my LG Tromm front load
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Posted on Sep 15, 2010
heatman101
  • 43501 Answers
SOURCE: LG Tromm Washing Machine Won't Drain code
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
  • 6277 Answers
SOURCE: washing machine stops after wash,
LG's 'OE' means 'drain (Output) error.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Have an LG FRONT LOADER WASHING MACHINE THAT IS OVERFILLING
Make sure that you get the correct pressure switch and also check that the rubber hose that comes off the tub onto the pressure switch is completely clean inside. Any gunk that prevents the pressure build up in the tub, when water is being taken on, from going up the pipe to the switch will cause an overflow error FE.
This could also be a faulty water inlet valve, but more likely the switch.
Apr 21, 2015 | LG Washing Machines
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
"OE" error. Filter cleaned but makes terrible
You still have something caught in the drain line on the machine. Check the filter again and the lines coming from the tub to the pump, and from the pump to the waste line. Here is a link to LG's document on the "OE" error.
Jan 10, 2011 | LG WM2277H Front Load Washer
OE code but will not drain and spin
LG Error quick list. Print it and post it near the washer:
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
middle of L. Thermister out
CE: Over amping
EE: eeprom out
PF: power failure
My Freebie manuals and repair notes are HERE
Dec 23, 2010 | LG WM2455 Front Load Washer
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
