Question about Car Audio & Video
Software zapco amp
I have a zapco dc1100 amp that was pro installed, it is powering two jl 10w3v3s. when i got it back the bass was lacking, but present. I got the software to adjust and heighten my bass. after hooking up my laptop i was able to open the program to adjust my sound. though while tweaking the switches no sound was changing, and after a few minutes of this the bass died completely. The amp is still receiving power, or at least the power light is still lit up green. I was unable to get the sound back and ultimately gave up for the night. Have you ever heard of this problem? Please help.
Shuttle83
  • 1139 Answers
SOURCE: jl 500/1 no sound, green light
This is an indication that the MOSFETs are ok but the driver stages may have a problem. Get a schematic find the pre-amp stages and test the voltages levels there as compared to the schematic. I do believe that you will find the problem in the pre-driver pre-amp atages.
Posted on Sep 06, 2007
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Posted on Oct 03, 2007
  • 160 Answers
SOURCE: have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Posted on Dec 01, 2008
LVT7857
  • 116 Answers
SOURCE: Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • 323 Answers
SOURCE: JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
This is normally due to clipping of your sub. Try reducing your low pass frequency to half and volume gain on your amp to 1/2. Your amp circuitry is over-heating. It's not designed to run like that. Use minimal gain on your amp and use your head unit to increase your bass. Turn up your stereo 'til you begin to distortion from there adjust your gains to your listening volume.
Posted on Feb 10, 2009
Amp shuts off.
check the connection of power connection and the remote connection tone amp,you can check also you inside by using your hand ,turn on the amp and wiggle it the power connection parts.
Jun 15, 2013 | Jl Audio 500/1 Car Audio Amplifier
I have a jl audio 500/1. I had the amp professionally installed. The amp played for 2 days and no it has no sound but the power will come on. what could be the problem. I have new rca jacks, 4 guage power...
Go back to where you got it installed and ask them to fix it.
If you don't want to do that I would recommend going to another good car audio shop and getting them to check it out.
You can test it yourself by hooking up an iPod to it using a Headphone to RCA cable.. test at low volume first.
Dec 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
Bass only going to rear speakers. How do I get
Hello michaelandta,
Check your filter settings on the front channels. It sounds like they may be set to "high pass" which would eliminate the bass frequencies. If you are using the amp to power normal speakers, it's usually best to set the filters for "full range". If the amp only has "low pass" and "high pass" settings, turn them both OFF.
Hope this helps.
Sep 11, 2009 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
No sound out of subs
undo all the wires to the amp and the speakers and simply rewire em.
Feb 25, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Bass boost
yes! just set it to bridge mode connection!
Oct 12, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
