Question about Brother LX2500 Heavy Duty 17-Stitch Free-Arm Sewing Machine Refurbished XL2500
The needle on my sewing machine doesn't move? The needle and handwheel on my Brother LX2500 machine will not move when I press the foot pedal. Everything else seems to be working fine. I can hear the motor run, but the needle just won't move.
    Novelist:
  • 268 Answers
Turn the bobbin winder on again, then off, crisply. Or if you need to loosen the clutch in the center of the handwheel to wind a bobbin, tighten up the clutch again.
Posted on May 22, 2014
    Champion:
  • 208 Answers
If the balance wheel is moving when you press on the control then it needs tightening, if the balance wheel does not turn when you press on the control and you can hear the motor spinning then the belt is broken
Posted on Oct 25, 2013
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Needle Wont Move When Pedal Is Pressed
check if the foot pedal connect correctly or not change the footpedal if still not working
Jan 18, 2014 | Singer 2250 Tradition Basic 10-Stitch...
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
Brother sewing machines lx2500
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster i need help to :{
Nov 25, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother pe770 - needle threader is stuck in the down position while trying to thread it
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or twice to raise the needle.
> The needle is correctly raised when the mark on the handwheel is at the top, as shown below. Check the handwheel and, if this mark is not at this position, press (Needle position button) until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
Sep 17, 2011 | Brother PE770 Computerized Sewing Machine
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
Feb 26, 2010 | Singer 3116 Simple
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
scott
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my...
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Jul 20, 2009 | PfaFF Sewing Machines
Brother LX2500 Heavy Duty 17-Stitch Free-Arm Sewing Machine Refurbished XL2500 Logo
572 people viewed this question
Top Brother Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Brother Furniture Expert? Answer questions, earn points and help others
