Question about RCA F27252GY 27" TV
Video channel input
No remote need to switch it to vcr inport how can i do that
5 Suggested Answers
SOURCE: Video Input
what if you do not have the remote and need to switch to input?
Posted on Dec 26, 2007
daniel719
  • 240 Answers
SOURCE: Cannot Switch over to AV Channel
you need an rca universall remote with you model number listed.
regards,
daniel.
Posted on Jan 11, 2009
  • 63 Answers
SOURCE: can't access video input channel
I believe you need the original remote to switch the input to video . I found the remote shown at PartStore.com with the original RCA part number 242524 at about $37.00 and also at MCMelectronics.com at around $31.00. There may be other sources also. Good luck.
Posted on Nov 05, 2009
gopakumarg43
  • 75581 Answers
SOURCE: Need to change input, no remote
There is no way to change the input to this set without its remote control.
Posted on Apr 13, 2012
How to hook up my video to a TV. I can get a picture on screen but cannot he VCR to playback. How do u work out what channel to play back videos on.
Connect the video out of the VCR to the video in on the TV. You will need to switch the TV input channel to video (use your remote to do this).
Jun 07, 2016 | Televison & Video
We have a digital tv but an anologue vcr so we bought a strong srt 5430 so we can record through our vcr but are having trouble conecting the vcr and set top box
You need a cable to go between the yellow (picture), red and white (sound) sockets on the strong to the VCR.
Those cables will connect to one of the VCRs AV inputs. You then need to use the VCR remote control to switch from the now defunct analogue tuner to the Line or AV input. Put your TV on the channel you use to watch video tapes. Switch on the Strong receiver. Do the switch to the Line or AV input on the VCR. When your VCR is on the correct input then you will see the picture from the Strong receiver on the TV. You can confirm it is the correct source by displaying the Strong's EPG.
When you come to make recordings, the Strong will need to be left on the channel that you want to tape. If your TV already has an aerial feed and isn't relying on the strong for its signal then you can watch another channel on TV.
Aug 27, 2014 | Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
There appears to be no 'menu' button on the remote
First make sure the cables are truly in the right places. The antenna or cable goes to the VCR's antenna input connector, and there should be a cable from the output connector to the TV's antenna input. Sometimes people get the input and output cables reversed.
The VCR's output to the TV will either be on channel 3 or 4. Those are the only choices, so you should be getting the signal on one of them. On some Sanyo models there is a switch on the back near the "out to TV" connector to select the channel. On others you need the remote to select through the VCR setup menu. Check the remote for a button labeled "TV/VCR" and press that while a tape is playing. That button controls whether the signal from the VCR goes to the TV, or if it just passes the antenna signal through to the TV. Try both channels 3 and 4 on the TV.
If you are never able to get a picture from the VCR on either channel, its RF output section may be bad. This can happen. You can get around this if your TV has a/v inputs available. Connect the red and white audio (red is right channel and white is the left) output jacks and yellow video output jack on the VCR to the corresponding inputs on the TV. Then switch the TV to the a/v input to watch the VCR.
Apr 12, 2009 | Sanyo Televison & Video
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
RCA F27252GY 27" TV Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
