Question about Home
Yoyo bidet The water temperature for the WASH
Yoyo bidet The water temperature for the WASH action is cold - what's the problem?
    Problem Solver:
  • 20 Answers
Possibily the heater is not working or a temp control not working. contact your local supplier or plumber
Posted on Aug 04, 2013
Im looking for intelliseat toilet temperature sensor
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White · 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Dec 04, 2016 | Ovens
The water no longer gets cold . What do I check ? Thanks !!
On a washing machine?
You have a hot fill inlet, you have a cold fill inlet. The controller dictates how much hot water and cold water to get the right temperature for the wash you have chosen. This is tested by the thermostat in base of the drum. The heater then warms the water to the correct temperature for the full wash.
Some washers are cold fill only and the heater in the washing machine does all the work. The wash cycles take a lot longer.
If you are in fact talking about a water cooler not getting cold, check the air filters and for dust on the compressor fins.
Jan 13, 2016 | Washing Machines
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Home Logo
50 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
