Question about Frigidaire Refrigerators
Hi I have a frigidaire side by side model flsc238ds1 give me the error "power failure" I check the compressor and is ok but not start dong get any cold temp. All lights and fans are working and the temp. Control. I don't if is the main control or the power inverte board. Some body help me .. .? Thanks
  • 4 more comments
  • viento86 Jul 31, 2013
    Testimonial: "No is no cooling.the compressor is not working. But I check the 3 winds and is ok. Also I tested whit other new compressor and not start ."
  • John Tripp
    John Tripp Jul 31, 2013
    You already changed the compressor without changing the inverter board? Have you changed refrigerator compressors before?
  • John Tripp
    The only way to test the compressor is with another inverter board. Your model uses the inverter in the link after my comments. Repair Clinic will take returns if the part does not fix this problem. http://www.repairclinic.com/PartDetail/I...
    Yes I change compressors before, I was thinking to get the inverter board but I want to make sure is the correct part, I notice the old inverter board have 2 big capacitor ,those are like bump , I order those and replaced but don't work, I will order the inverter board and tried . Thanks
    I miss understand u question, I change compressors befofe but I didn't on this fridge,I have ne compressors and I put one on the side to test the inverter board because this controls the power for the compressor has the wires to connect the comprssor
  • John Tripp
    You cannot test just any compressor with the inverter board. The compressor you have on the refrigerator you have is a varible speed compressor that can only be tested with a new or used inverter board because the inverter board changes the voltage from single phase 120 volts ac to 220 volt three phase power. Here is a link to a inverter that has been opened to expose swollen capacitors. Swollen capacitors are why this inverter does not work, http://appliance911seabreeze.com/WR55X10...
  • Frigidaire Master
  • 4,655 Answers
Is the refrigerator cooling? I will help you but you will need to respond, Sea Breeze
Posted on Jul 31, 2013
  • viento86 Aug 01, 2013
    Thank u for u help , I follow the link and is the same problem ,so already order a new power inverter,. Thank u again , good bless u.
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Posted on Sep 13, 2009
  • 1531 Answers
SOURCE: kitchen aid refrigerator model KSSC48QMS01
replace the condensor fan motor.
Posted on Feb 25, 2010
Refrigerators Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
