My JVC TH-D60 shuts off after 3 to 5 seconds when I turn it on?
SOURCE: subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Posted on Dec 05, 2007
marsrover
  • 682 Answers
SOURCE: jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Posted on Apr 06, 2008
VOTIT
  • 2071 Answers
SOURCE: JVC TH-D60- randomly get nothing
Static and scratching sound caused by dirt or dust in the PCB (printed circuit board) and loose or cold solder joint ;.Clean the circuit board with the use of laquer thinner or alcohol ,so static sound will gone.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 16, 2008
mlapres
  • 757 Answers
SOURCE: JVC RX-515VTN: When I turn it on, th ereciever
Check the rear panel for any loose connections, paying special attention to the speaker terminals. If you are using speaker wire without connectors, make sure that you have no stray strands of wire protruding outside the terminals or any broken strands.
Strand wire over time oxidizes and becomes brittle and easy to break so at any time the unit was moved while connected or anything else that would create tension on your connections it could easily break some wiring.
Also check the opposite ends of all of your connections at the speakers and input devices, i.e; DVD player, television etc.
Posted on Feb 10, 2011
Testimonial: "Thanks for the quick response. I have been messing with the speaker connections lately, so that is where I will start looking for the solution."
dunnbiker
  • 8546 Answers
SOURCE: JVC TH-S11 ...Shuts off after
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jun 04, 2011
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
Nov 16, 2014 | JVC GR Video Cameras
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
How do i hook up my tv to the sound system so i can hear regular tv through the speakers? I can hear it when i play a dvd but not regular tv shows.
The simplest way would be to run RCA cables from your Cable Box analog audio out (if THAT is where your TV programming comes from) to the available Audio In on the JVC. Page 9.
If the cable box has coaxial or optical digital audio OUT, run THAT (instead of the analog audio) to the correct Digital In connector. Page 8 and 9
This would free up the analog audio from the cable box to send directly to the TV's audio input for causal programming, like news, so you wouldn't need the JVC on.
http://www.retrevo.com/s/JVC-TH-D60-Home-Theater-Systems-review-manual/id/2771ag518/t/1-2/
Feb 07, 2011 | JVC THD-60 System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
I have a JVC TH-D60 dvd digital theater system. My problem is I can only get 2 speakers to work at a time. They all work but not at the same time
DVD movies are so recorded as to get specific sound from each speakers, for eg, if the scene involves a bee going in circles then, the sound is first heard from the left, the right, the back right and the back left, That should explain.
Oct 03, 2008 | JVC Audio Players & Recorders
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Jvc th-m45 shut off
Apr 06, 2008 | JVC TH-M45 System
Subwoofer shuts down
Nov 24, 2007 | JVC TH-M505 System
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
