Question about Rowenta DR5015 UltraSteam Handheld Fabric Garment Steamer Steam Brush, 110V, Continuous Pump, Var Steam, Clear Tank, Pad Brush Removes Lint DR5020DV
Rowenta dr5015 won't steam - Rowenta DR5015 UltraSteam Handheld Fabric Garment Steamer Steam Brush, 110V, Continuous Pump, Var Steam, Clear Tank, Pad Brush Removes Lint DR5020DV
Set Up
go to www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 02, 2012 | Rowenta IS9100 Steam Cleaner
How to set up and use
read your manual or download it from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Iron shuts off intermittently during use, therefore it won't steam. Before we go any further does this site charge for this service?
No charge for my answer, but you can contact an Expert on this type of appliances and discuss it further.
Jun 20, 2011 | Rowenta Vacuums
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
Rowenta Effective DX 1700 model---won't spray water?!
Mine was getting slow to steam, downloaded a manual (could only find model #1900, but close enough), and found out how to clean- fill with water, heat to the highest temp, hold over the sink horizontally and hold the steam lever over to the "self clean" position for one minute. That's supposed to purge the system of junk. Manual site: http://dl.owneriq.net/2/28c59722-2a7e-45ae-b333-c20240d7e9f5.pdf It's a free download.
Dec 29, 2010 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
How do i clean my rowenta steam iron
run some c.l.r clear through it
Sep 25, 2010 | Rowenta Vacuums
I was getting ready to iron a pair of pants that were polyesterrayon and 4% spandex. I thought I had my Rowenta iron turned down low enough but when I placed the iron on the pants they melted. Well...
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Jul 04, 2010 | Vacuums
Rowenta DR5015 UltraSteam Handheld Fabric Garment Steamer Steam Brush, 110V, Continuous Pump, Var Steam, Clear Tank, Pad Brush Removes Lint DR5020DV Logo
52 people viewed this question
Top Rowenta Vacuums Experts
Charles T Nevin
Charles T Nevin
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
