Question about Fellowes DM12C Shredder
I have a Fellows DM12ct paper shredder but the blades are dull and no longer shred paper. You can see the cross cut but the paper is still intact.
SOURCE: Shredder stops in the middle of shredding and won't shred.
I have the same problem with my shredder. I opened it up and found one of the gearwheels had teeth missing. That is why the partial shredding could not advance further. I was able to remove the part and am now hunting for a replacement.
Posted on Feb 15, 2008
SOURCE: novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Posted on Aug 17, 2008
SOURCE: Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Posted on Mar 05, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
  • 105 Answers
SOURCE: I have a Fellows Powershred ps 60cc and removed
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Posted on Nov 17, 2009
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
Why does my paper shredder make a clicking sound when I try to shred a piece of paper?
Try putting a piece of paper in enough to start it running, but not so far as to go into the shredder. See if it will run for a minute or two. Sounds as though it may be over heating.
May 03, 2014 | Generic aurora as1016cd heavy duty...
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
This shredder overheats after 1 to 2 thin weight sheets of paper. Says it does up to 10 sheets but can not handle more then 1 sheet at a time. I have cleaned and cleaned the cutters with no improovement
Have you "oiled" the machine ever.????
Cross-cut shredders require occasional oiling with "shredder oil" to help clear out debris that is made in the shredding process from the cutting mechanism. Get some shredder oil and pour it directly across the cutting blades where you insert the paper... this should help...the occassionaly pour some oil onto a sheet of the paper to be shredded prior to shredding it.
Oct 28, 2010 | Royal VF1000MX Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
BLADES LOCK UP/JAM ON ROYAL 9X HEAVY DUTY CROSS CUT PAPER SHREDDER.
Have you "oiled" the machine.... put some shredder oil on a piece of paper and shred it....do this a few times to get oil into the cutting blades and see if that helps.
Jan 18, 2010 | Royal Office Equipment & Supplies
Paper gets stuck on the blades so it does not shred the paper all the way
Your shredder may be getting dull ... there is no practical way to sharpen the cutting blades.
Shred fewer sheets at a time and use shredder oil available at the big box store and other fine establishments. Follow package directions when applying the shredder oil.
I hope this helps
Please vote
Thanks for your interest in FixYa.com
Dec 15, 2009 | Royal VF700 Cross-Cut Shredder
My blades are dull and will not cut the paper. The Royal 12 X Cross cutter is a stronger shredder but it won't take but a very sheets and tears the paper instead of shredding it up. Help!
When I bought my last shredder it came with a small bottle of oil. The instructions said to put a few drops of oil on the blades now and then.
I think the oil was actually canola oil.
Read your manual to see if it suggests any lubrication.
Sep 25, 2009 | Royal Office Equipment & Supplies
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
Fellowes DM12C Shredder Logo
117 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
