Question about HP Photosmart 735 Digital Camera
HP 735 power on
A few times in the past my HP 735 would not switch on on the first attempt, but did switch on and performed normaly after the second attempt. Now it does not switch on at all, I have ensured that the batteries are fully charged,even replaced them with new ones, but still no joy. What is the worst case senario I could expect, i.s what is the most it could cost to repair? Could you recommend where to take it for repairs?
  • 641 Answers
It sound like an on/off switch issue. Best thing will be contact HP appropriate service center and ask how much will cost to repair it. It might be that the reparing cost will be such that it will not be worth to repair it.
Posted on Aug 31, 2007
We have marathon generator running normaly but when applying a load in just a seconds it shutdowns,what is the possible causes of this?
Assuming it is not overloaded, check the engine to make sure it is tuned and can develop full HP. If it is running at peak performance, then chances are you have a short in the stator, pulling more than rated output.
Mar 01, 2015 | Electrical Supplies
My laptop is not turnnig-on!
Try removing the battery and running from the AC power supply only. If this works, your battery probably can no longer hold a charge and the battery will need to be replaced.
Removing the battery allows the power supply to power your laptop rather than trying to charge a dead battery
May 17, 2009 | HP Pavilion dv2214us Notebook
Not Powering up.
Hello there
I understand your Notebook is not powering ON. You can perform power drain to resolve the issue.
1) Perform power drain. Follow below steps for Power drain.
a) Shut down the Notebook and remove the battery completely from the Notebook.
b) Press and hold the Power button for 30-50 seconds.( This will discharge any static electricity in the picture tube)..
c) Connect the battery and switch on the Notebook.
If the problem still persists log on to HP.com 24X7 chat support by clicking the below link or pasting it in the address bar of a web browser.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Feb 16, 2009 | HP Compaq nc6000 Notebook
It will not power on.
Hi Ken if you bought your 735 new it has a cradle a (docking station)if you had tried the batteries and still not powering up you need to eliminate other possibilitys try powering up the camera on the docking station make sure power cord is on if the cam fires up that way then this will no doubt a camera shop fix,I repair on the side would be interested in trying the repair to at least give you some more closure on deciding if the cost of the repair is worth considering these are and been outdated quite sometime ago and a repair could supercede the price of the camera when purchased if you want e-mail me and i could try a few walk threws with you and see if we can cure it.
thanks,steve
Sep 01, 2008 | HP Photosmart 735 Digital Camera
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Aug 09, 2008 | Archos 604 Digital Media Player
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
Cartrige jam message
I am Lawrence, following are few trouble shooting steps that should help in resolving the issue.
Please follow the below given instructions from the below article to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&cc=us&lc=en&dlc=en&product=441127&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
If the issue still persists follow the below given instructions to resolve the issue.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.1
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Regards,
Lawrence
Jan 02, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart 735 Digital Camera Logo
59 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
