Question about Bruno VSL 670 Wheelchair Lift - Used Power Chair Lifts
I have a Bruno vsl-6000 that from time to time just does nothing
Have a Bruno typhoon handicap scooter. When I turn key on there's a red light that blinks and nothing moves what could be the trouble?
That's a code. You'll need to look it up in your owners manual or get the information from their website.
Sep 03, 2017 | Televison & Video
Bruno vsl 6000 lift stops every 2inches on way up loading chair.
A loose wire connection, or loose or intermittent safety edge.
Jul 03, 2015 | Health & Beauty
How do ichange batteries on a bruno cub mobility scooter
Find out where the batteries are. Find out if there is a plug disconnect to the motor controller. You have to change the batteries
with the right size and amperage capacity. Install the batteries
one at time with the correct polarity on the cables.
Feb 14, 2015 | Bruno Cub 30 Batteries
Need manual for ASL-215 bruno lift
You should contact Bruno directly. Here's the link to their support page Request Information on Any Bruno Product
Feb 09, 2015 | Health & Beauty
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
I require a technical/ installation manual for a Bruno VSL-692 lift. Bruno main office said to contact a dealer, but no dealers in my area will help me with this.
If Google don't have your particular model # then down load the next best model thats on google, It may be better then no manual.
Feb 02, 2013 | Health & Beauty
Bruno VSL 670 Wheelchair Lift - Used Power Chair Lifts Logo
Top Bruno Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Bruno Health and Beauty Expert? Answer questions, earn points and help others
