Question about Skull Candy Smokin' Buds Headphones
How do I change tracks - Skull Candy Smokin' Buds Headphones
How do I fix my 8 track player?
These are operate by a solenoid and a ratchet that moves the head up and down. Pressing the channel changing button activates the solenoid. A metal strip on the tape also activates the solenoid. In this case either the solenoid has stopped working, it might be stuck! Or the ratchet is damaged. Most of the time it sticks on channel 4 with this fault, though it can stick on others.
Apr 08, 2016 | Audio Players & Recorders
Can i trace my iphone 5 with imi as it has been stolen
nope, the imi can be changed in the phone so its not of any use other than activating the phone, track my iphone through apple might if you had that service on, other than that tracking phones like that is of little use as it hardly ever works
Jan 29, 2015 | Apple iPhone 5
Track DML changes in SQL server database
You can track DML changes of of DELETE, UPDATE and INSERT operations with the help of SQL server change tracking tool and get real-time notification of critical DML changes.
Please, take a look at this link : http://www.sqlserverchangetracking.com
Jan 06, 2014 | Computers & Internet
TRACK CONTROLLER DOES NOT ALLOW ME TO CHANGE TO DIFFERENT TRACKS
You are recording everything as one long track.
Either break it up into the tracks you want before you record, or break up your long track into many tracks after you record. Or create the tracks you want as you record.
That's the joy of using a minidisc - the editing and titling features.
Dec 25, 2012 | Audio Players & Recorders
How can i activate new ring tones and text alert tones on my sony ericsson satio phone ? also when trying to download apps it sayd redownload and when i do it shows an error !!! any help would be so...
you can set a ring tone in play view!
hope this helps please remember to take the time and give me a good rating if you appreciated my help.
Managing tracks in play view
You can manage your tracks in many ways when playing them. You can, for example,
delete a track, send a track, set a track as your ringtone or add a track to a playlist.
The following icons may appear in the touchbar when a track is playing:
Exit the play view and go back to the previous level
Go to the music library
Adjust the volume
View more commands
Delete the current track
Send the current track
Set the current track as your ringtone
Add the current track to a playlist
View track information
Minimise the music player
To delete a track
1 When the music player is open, tap > .
2 Select an option.
To send a track
2 Select a sending method.
To set
also can be done in personal settings:
Personal settings
You can personalise your phone by changing the standby screen, profile or themes.
Profiles
You can change settings such as the ring volume and vibrating alert to suit different
locations. You can create new profiles or change preset profiles.
To change the profile
1 Select Menu > Settings > Personal > Profiles.
2 Tap a profile and select Activate.
3 Select Back.
You can also press and then select a profile.
To edit a profile
2 Tap a profile and select Personalise.
3 Change the settings and select Back.
To create a new profile
2 Select Options > Create new.
3 Enter the settings and select Back.
Mar 26, 2010 | Sony Ericsson Satio Cell Phone
How doI get rid of track changes when editing a
There are various ways to hide the tracked changes or comments — butall the changes that were made while the Track Changes feature wasturned on and all the comments that were inserted remain part of thedocument until they are accepted or rejected (or, in the case ofcomments, deleted).
Word 2007 provides a feature called Document Inspector thatallows you to check any document for tracked changes, comments, hiddentext, and other personal information. To check a document:
  1. Open the document you want to inspect for tracked changes and comments.
  2. Click the Microsoft Office Button default.aspx?assetid=za100771021033, point to Prepare, and then click Inspect Document.
  3. In the Document Inspector dialog box, click Inspect.
  4. Review the inspection results. If Document Inspector finds comments and tracked changes, you are prompted to click Remove All next to Comments, Revisions, Versions, and Annotations.
  5. Click Reinspect or Close.
To get rid of tracked changes and comments, you need to accept or reject the changes and delete the comments. Here's how:
  1. On the Review tab, in the Tracking group, click the arrow next to Show Markup.default.aspx?assetid=za102097011033
  2. Make sure a check mark appears next to each of the following items:
    • Comments
    • Ink Annotations
    • Insertions and Deletions
    • Formatting
    • Reviewers (Point to Reviewers and make sure that All Reviewers is selected.)
    If a check mark does not appear next to an item, click the item to select it.
  3. On the Review tab, in the Changes group, click Next or Previous.default.aspx?assetid=za101539421033
  4. Do one of the following:
    • In the Changes group, click Accept.
    • In the Changes group, click Reject.
    • In the Comments group, click Delete.
  5. Repeat steps 3 and 4 until all the tracked changes in the documenthave been accepted or rejected and all the comments have been deleted.
Notes
  • If you know that you want to accept all the changes, click Accept, and then click Accept All Changes in Document.
  • If you know that you want to reject all the changes, click Reject, and then click Reject All Changes in Document.
  • To remove all comments, you must delete them. In the Comments group, click the arrow next to Delete, and then click Delete All Comments in Document.
Aug 18, 2009 | Microsoft Windows XP Professional SP3 Full...
Icrosoft word tracking mode I received a document with changes in tracking mode I accepted all changes and saved. Now I cannot turn off tracking mode. What to do?
Turn off change tracking When you turn off change tracking, you can revise the document without marking what has changed. Turning off the Track Changes feature does not remove any changes that have already been tracked.
Important To remove tracked changes, use the Accept and Reject commands on the Review tab in the Changes group.
  • On the Review tab, in the Tracking group, click the Track Changes image. default.aspx?assetid=za102097011033
May 26, 2009 | Microsoft Office Communications 2007...
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Tempo change
click track on the play bar where u edit the tempo thers track and then fixed
Oct 28, 2008 | Steinberg Cubase SX3
Skull Candy Smokin' Buds Headphones Logo
57 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Owen Barnes
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
