Lavamat 86820 error code ce - Washing Machines
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
SOURCE: AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Posted on Dec 28, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
kapishtech
  • 2272 Answers
SOURCE: AEG OKO LAVAMAT 86820 Update
CCU means the computer control board.The CCU can also be called the main circuit board of the machine.The main circuit board is the board which controls all the other functions in the machine.All the other electric parts in the machine gets signal/command from main board to function.If main board is faulty then it will not let the command to other parts to function.But if main board is partially faulty then it will control some functions but not all.In both cases partially or complete faulty main board.The board has to be replaced.As per the fault which you have explained it indicates faulty main board,because the power cord is passing power to the machine but board is not functioning properly.----------- To get required part you can get it from partsselect.com or fron searspartsearch.com -------------. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 14, 2010
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
What means Error Code CE on a AEG 86820 Update washing machine?
The water distributer is out of order there are little plastic wheels 3 of them one orange, yellow and white, the orange is most likely stuck so you have to replace the hole water distributer app. $ 100.00 for the part.
Jun 07, 2014 | AEG Washing Machines
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Jul 04, 2009 | AEG Washing Machines
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Rafiq
Aug 27, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
